Small Block or Big Block?
Old Nov 11, 2014 | 10:57 PM
  #41
dugsgms74's Avatar
dugsgms74
I like the early 90's ZR 1. Engine ......old school HP
Shame it was not made the std Chevrolet engine
All alloy, DOHC and 4 valves per cylinder doesn't sound very old school to me.
Old Nov 12, 2014 | 07:55 AM
  #42
Jughead's Avatar
Jughead
Senior Member since 1492
From: Just because I'm paranoid doesn't mean people aren't out to get me...
St. Jude Donor '09
Originally Posted by 68/70Vette
If you want to put a classical BB engine in a C3...please install aluminum heads and aluminum intake manifold, if necessary. The classical BB in a C3 is a cast iron pig. In 1970, the BB's even came with cast iron intake manifolds. I've driven these C3's with the all cast iron BB engine pigs, and you can really tell it on even just street cornering. They are just too front heavy. My project car is currently slated with an all aluminum BB engine.
Stock iron BB heads weigh 80lb each. The GMPP aluminum head I have weighed 40lb each. A savings of 80lb.....
A bare 454 blocked weighed in at 265lb...... I think that bare aluminum big block weighs about 110lb.
Old Nov 12, 2014 | 11:56 AM
  #43
bluedawg's Avatar
bluedawg
If weight is an issue, wouldn't a swap using aluminum heads and intake bring the weight down to small block territory?
DO MA NEU!
Old Nov 12, 2014 | 12:07 PM
  #44
bashcraft's Avatar
bashcraft
DO MA NEU!
Yes, but don't bring logic into this. The small block guys like to argue.
Old Nov 12, 2014 | 12:36 PM
  #45
bluedawg's Avatar
bluedawg
Oh...Lord forbid. He hehe. I got a 454 in the garage on the stand, would like to build a procharged 496" out of it one day, but even a 496" or 477" with aluminum heads/ intake and a roller cam should put my current 400" to shame.
DO MA NEU!
Old Nov 12, 2014 | 12:51 PM
  #46
cv67's Avatar
cv67
St. Jude Donor '05
Alum heads intake brackets water pump radiator etc brings it way down
at the end of the day unless youre really cornering hard youll hardly notice a difference, With the added torque who cares anway
You can get similar hp with sb and bb to a point what the sb guys dont realize is the tq gain at all levels you just cant duplicate it without forced induction....which adds weight and takes power to turn. not even worth really arguing about
Figure your budget needs name your poison then spend 2x as much anyway LOL
Old Nov 12, 2014 | 10:13 PM
  #47
bluedawg's Avatar
bluedawg
If, I mean if there was a power goal, that would help decided which engine, it's easier to hit a power goal with more cid, plus manners are better at that power goal. Obviously if all you can get is the goal, you could go bankrupt either way, but say 600 horse was the goal, a 496 probably woulnt cost much more and would be better mannered.
Old Nov 13, 2014 | 10:42 AM
  #48
Little Mouse's Avatar
Little Mouse
600 hp as your goal to make sure its really dependable in a SBC you need at least an $1800.00 SHP dart block, aftermarket heads pretty good ones in cost , roller camshaft expense.
Anybody can make a 600 hp BBC using a 2 bolt factory 454 pickup block, old factory heads, and a flat tappet cam by using a 496 stroker crank. You can build the BBC worlds cheaper if you use your head don't get carried away on a bunch of stuff not needed. 4 bolt mains on a BBC fine if you were turning it 7600 rpm for several hours at a time the way they did when they used them in nascar.
You have to jump through hoops of money to get a SBC really reliable at that level of power. Because its a SBC trying to pretend its something else.
There's people on this forum have $12,000, $15,000 trying to get a SBC reliable when they could have done it with just old factory BBC parts.
Old Nov 13, 2014 | 12:39 PM
  #49
7t9l82's Avatar
7t9l82
and i couldn't agree more. there are tons of aluminum heads available used that would lighten the load even more. the closer to stock a build is the more reliable it will generally be , and that much less temperamental.
Old Nov 13, 2014 | 06:09 PM
  #50
76Rat's Avatar
76Rat
You should tell that to all the anybody's out there that have less than 600 HP (almost everyone) This sounds really easy to do.
Now that is funny! Is this the part where you tell him that a 350hp big block is a much better motor then a 450hp small block just because its a Big Block or is this just a bit of
Old Nov 13, 2014 | 06:40 PM
  #51
lurch59's Avatar
lurch59
That is precisely what Mark Jones does, with factory iron heads.
Well, for the sake of argument it depends on where the horsepower is made. My 496 makes 600 hp at 4000 rpm. If the small block is making 450 hp at 7000 rpm, it won't live very long running up that high.
Nobody has mentioned the inherent advantages of the big block porcupine heads over the small block heads, I'm surprised.
Old Nov 13, 2014 | 06:42 PM
  #52
DO2G's Avatar
DO2G
I'm going Big Block!
Mark Jones at VortecPro is building the motor. We're working out all the details/specs now.
More to follow.....
Old Nov 13, 2014 | 07:40 PM
  #53
lurch59's Avatar
lurch59
More to follow.....
My 496 is a Mark Jones build, I think you made a wise choice. Are you going with aluminum heads?
Old Nov 13, 2014 | 07:44 PM
  #54
BLUE1972's Avatar
BLUE1972
More to follow.....
World has a nice 800 CI block, makes 850hp and 800'lbs torque,
I would go with a LS engine and have the best of both worlds. P.S. I really don't know what you would do with 850hp, except buy rear tires every Friday.
My 85 has 540hp with a small block, but it has 335's in the rear. It still slides and smokes them.
The sound of a big block is awesome, but drivability gives the small block the edge, my 350/350 is great. 3.36 rear stock tires. And you'r feet don't melt to the floor. Soon to be a 5 spd.
Old Nov 13, 2014 | 08:14 PM
  #55
Corey_68's Avatar
Corey_68
Depends on what SB, a 327 and especially a DZ302 can live at that rpm and then some all day long.
Old Nov 13, 2014 | 10:34 PM
  #56
bluedawg's Avatar
bluedawg
But at what power level, just cause it will hit that power level and live doesn't nessicerily mean it's making tons of power there.
DO MA NEU!
Old Nov 13, 2014 | 11:16 PM
  #57
Les's Avatar
Les
More to follow.....
That's going to be some kind of fun! Do keep us posted please.
To Small Block or Big Block?
Old Nov 14, 2014 | 02:12 AM
  #58
bluedawg's Avatar
bluedawg
More to follow.....
I've never heard bad about Mark Jones.
DO MA NEU!
Old Nov 14, 2014 | 06:31 AM
  #59
tt 383's Avatar
tt 383
DO MA NEU!
I have... but that guy was a DH, and seemed to be a hack lol. I ssem to remember wire nuts in dizzy wiring!
Old Nov 14, 2014 | 07:55 AM
  #60
cv67's Avatar
cv67
St. Jude Donor '05
Vortecpro builds some good stuff
Gladly trade my 5xx sbc for someones boat anchor 600hp BBC. Nooo problem
