I may be crazy, but I still don't think any small block (G1, 2, 3, 4) can touch a big-block when it comes to maximum potential.
That said, in a stock C3 chassis I think you can easily make "too much" power with a fairly moderate small block build. 400, 500 hp are "easy" to make these days.
I love the small block Chevy. Small blocks are easy, cheap, and can definitely be built enough to give me the fun power I am looking for in these cars.
468 BB 600HP - $8K (But need hood, headers, etc.) total cost $11K
For a 1978 with a 4 speed 3.73 gears. Tranny and rear are good.
Just a fun car driven mostly on the street and lots of spinning tires....
If you're talking about STOCK "Tranny and rear are good" they won't be for long behind a 600 HP big block. Remember it's torque, not HP that breaks parts.
Big blocks shine but they do invite trouble in a hurry when pushed hard. Breaking the wheels loose at 60-70mph is common and driving into a corner with a set of cobra GT Cooper tires might have you changing your underwear but you'll get use to it!
I just installed a 425 HP 383 Ina 79 with a 700R4 trans. It has more power than most can handle. It is near impossible to hook it up Ina hard launch. Honestly on street tires the difference between 520 and 600 HP you will never realize. Neither one will hook on the street. My car has over 500HP in. SB and it is a hoot to drive. Any more HP and it is just bragging rights on the street. Now if you put slicks on different story but you better have a beefed up trans and very good rear end components
Had nothing but hot small blocks for years but I will say this no matter wha tthe HP rating is youll never equal the torque of a BB the fun factor is way way worth it.
If I had the funds Id trade up in a hot second
A large CI sbc as mentioned is a valid option also but it will practically cost as much as the BBC. These days a 496 is a small big block but enough to get you in plenty of trouble.
Sure you need to upgrade things but thats par for the course. A BBC doesnt need a bunch of gear or rpm to have a good time. just crack the throttle and you shoot ahead of most real easily
My just rebuilt L-82 355 is easily putting out 425+ Gross HP now and is has unbelievable low end and mid range grunt for a SBC-AFR heads and roller cam. The 355 pulls hard in any gear with the 4 speed with 3.70 gears even down low….As Gordon says beyond 500 HP on the street in a C3 the power becomes more about bragging. I hardly have room to rev the engine past 6,000 RPM in 3 rd gear since most of the time I run out of road. So how can I compare my new L-82 to a BB C3-I can't but I can compare the HP/Torque to my 10 C6Z06 LS7 427 which has a boat load of NET HP and Torque-EVERYWHERE-more than most BB can get to the ground in a C3. The 78 does not have the same punch as the LS7 but its certainly in the game now.You can get 90% of the HP/Torque from a built SB without the mass/weight of the BB. SBC all the way.
I'm not qualified to offer an opinion, I have a 454 but have never owned an SBC, but I will offer this line that I read not long ago and it stuck with me:
"There is no replacement for displacement."
You can build a 496 BBC just as cheap as a 427 BBC and do it cheaper then a 427 SBC even begining to make the same power. The heads on them flow air a lot better whether there just stock heads or aftermarket heads. A simple two bolt block out of pickup will handle pretty big power but not the SBC. The weight not a real factor unless your into really serious road racing a vette has a real good front to rear balance and even the heavy'st of them all a BBC with iron heads and iron intake manifold only change the weight distribution by 1 percent a non player for the vast majority of people.
You'd probably be happy with either choice- I love and have both a smallblock and a bigblock. My avatar car has a 355 like "jb" does, except it has AFR 195s, 11 to 1 comp ratio, a more aggressive cam, long tube headers, etc. to go with 4.10 gears. It has a very bad attitude, revs out hard to 6500-7000 RPMs, and yet it still has strong, crisp throttle response just off idle. I love that little engine.
However, my '69 427 has all that and then some. Given your choice, I'd probably go with the bigblock. It can deliver great performance without breathing hard and can deliver eye popping performance when you decide to really let it rip. Truthfully, either of your choices will make enough power to obliterate normal street tires, as touched upon by Gordon. You'll need a good drag radial out back either way. Nitto drag radials could still be overcome too easily on my '69 but MT ET Street Radials now get the job done once they've gotten hot. Heck, that car probably runs the 1/4 mile quicker than my C6 Z06 could because of those tires. Whatever you choose, you're in for a lot of fun.
bottom line, in a 3000 pound car you need at least 600 to 650hp to be competitive.and you can get that very easy with a small block, but if you do go big with a big block you need to make enough hp to make up for the weight at least 700 to 750hp.
I say go BB. SBs can make a lot of power for sure but the BBs have a the large bore on their side. Big bore=big valves and big valves=big flow at mid lift. People tend to only look a flow at high lift numbers, max flow is only reached once per valve opening while most of the time the valve is somewhere in mid lift. What this means is that you don't need as radical of a cam to make big power with a BB. Besides, BBs don't weigh that much more than SBs especially when you factor in aluminum heads and the engine is so far back in a vette chassis that the weight is less noticeable anyway.
I think if you look at both of you're choices you'll find that the BB makes more power with less cam and the power spread is wider, all great things in a street car.
