'69 Manual Trans./Steering Column Cable
Any ideas??
Thanks!
Have you removed the cable to see how free the lever is on the steering column?
Do you have both the brackets in place?
If you look at the trans. mount bracket and the shifter mount pin, you will see a small "elevation" change when the shifter linkage rotates. I think this was a design mistake. I think a cable is to be PULLED...not PUSHED.
So, I thank your wisdom and hope you have more info to help me figure out this problem
Thanks again!!
I think you're mistaken about THIS cable being designed to either 'push' or 'pull'
With a lever at each end the cable is performing the same task no matter which way it is traveling unless one of the lever's takes more force to move than it was intended to.
Is there ANY chance the cable is on backwards?
Does either swaged fitting need to be 'twisted' in order to make it's connection? This might cause some binding of the cable in the sheath.
Regards,
Alan
Transmission end.
Firewall.
Column Lever.
Regards,
Alan
Transmission end.
Firewall.
Column Lever.
I understand the cable! What I was saying was that the cable is pushed to lock the column...and that is when the problem happens. Again, cable is NOT designed to push something...it can bend! Try it!
The column lever never has been designed to push or pull...the reverse lever is the one that does the push and pull.
Both ends of the cable are exactly the same, so it can not be backwards. The ends of the cable align perfectly. If you look at the housing beside the reverse lever and the reverse lever, you will see the reverse lever "pin" rotating. When you see any rotation, you will see the end of the cable will raise and lower the elevation. This can be part is the problem.
Also, thanks for the message from Willcox! When I checked the transmission brackets, I noticed the front transmission bracket is missing! So, if the bracket is not there, the rear end of the housing possibly can change the elevation or maybe sideways. That can also be part of the problem. I communicated with Willcox to see it they have the bracket, but I have not received their response.
Thanks again for your thought Alan!!! I will let you know more when I finally fix it!
John
Regards,
Alan
Transmission end.
Firewall.
Column Lever.
Here's the forward clamp installed.
Even with that much 'kink' in the cable it moves the levers at each end in either direction.
Regards,
Alan
Here's the normal curve in the cable as it travels from the column bracket to the first clamp on the transmission.
John
Steve L
73 coupe since new
I mentioned about turning the cable if it's installed backwards because I wondered if the fittings swaged to each of it's ends were 'clocked' in a certain position so that if installed backward the inner cable would have a 'twist' in it.
Regards,
Alan
When I did more research, I found out the cable is a "replacement" cable (Ecklers #46267) NOT a "reproduction" cable (Ecklers #53310).
That is why I said both ends are the same for the "replacement" cable. Obviously, the reproduction cable has different ends. I see two differences with the transmission end of the two cables...the "housing" female diameter and the shape of the "tip" of the housing.
I am waiting for my reproduction cable and hope to get it Tuesday.
John
