77 Turn/Wiper Switch Question
Old Nov 14, 2014 | 11:53 AM
ted13b's Avatar
ted13b
Default 77 Turn/Wiper Switch Question
I've had one problem with my 77 that really bugs me. The turn signal switch works fine, but as you move the lever it rotates too easily, turning the wipers on. Has anyone else run into this? Is this an issue with the turn signal switch, the wiper switch, or the pivot?
Old Nov 14, 2014 | 08:38 PM
Uintah's Avatar
Uintah
My 77 doesn't accidentally turn the wipers on while using the turn signal or dimmer function. The wiper rotation seems to have a click feel when turning it to low or high. Sounds like it might be wear from use within the switch.
You probably already know the switch/lever are out of production and very difficult to find.
Old Nov 15, 2014 | 09:47 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
My money says the problem is age.
Old Nov 15, 2014 | 04:04 PM
Willcox Corvette's Avatar
0Willcox Corvette
Former Vendor
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
As long as its working I'd be happy... on one makes the switch and finding a new or good used replacement is next to impossible.
Willcox
To 77 Turn/Wiper Switch Question
