HELP!
Old Aug 2, 2002 | 07:40 PM
Twin_Turbo's Avatar
Twin_Turbo
Default HELP!
This has been bugging me some time.
What are the 2 "brackets" for under the 80-82 bumper.
I mean the 2 that are mounted under the bumper bar itself (the one mounted on the enersorbers and has the impact cushions on it)
Marck
[Modified by Twinnie, 5:43 PM 8/2/2002]
Old Aug 2, 2002 | 11:01 PM
1yy07's Avatar
1yy07
Default Re: HELP! (Twinnie)
Mr. Twinnie, tow brackets? :smash:
Old Aug 2, 2002 | 11:02 PM
QuickVet's Avatar
QuickVet
Default Re: HELP! (1yy07)
:confused:
Old Aug 3, 2002 | 01:09 AM
Twin_Turbo's Avatar
Twin_Turbo
nobody knows this? Yeehaa, I just asked the mother of all questions :)
Wel since they obviously don't do anything on my car I'll use them to mount my new mufflers to once I get the car back together
Marck
Old Aug 3, 2002 | 11:13 AM
Monty's Avatar
Monty
I always assumed they were tow brackets, or strap down brackets as well.
Old Aug 3, 2002 | 03:39 PM
Twin_Turbo's Avatar
Twin_Turbo
Default Re: HELP! (Monty)
I'd believe strap down brackets before tow brackets. However why would anyone put strap down brackets on a car... must be something else [;)]
Marck
Old Aug 3, 2002 | 03:54 PM
PROSOUTH's Avatar
PROSOUTH
From: Manchester, Dead Center in the Middle of TN 25 miles to Jack Daniels,10 miles to Geo Dickle, and .8 mile from the Liquor Store at I-24 Exit 114
St. Jude Donor '05
Marck, According to the 1980 Assembly Manual #14028582 Bracket is noted as a "Towing Bracket"
Go for it!
I had already decided that was where I was going to mount mine also. Hope this helped.
I got a deal on a ( get this ) 3 1/2" BORLA Sportsman 16" Circle Track SS Muffler for $50 NIB. Well the deal was good but the other one to make a pair was $269.00 from Summitt. They are a Three Chamber muffler and are not like the straight through other ( and less expensive $134 ) model. I think it will be a workable piece and it's gonna look mean hanging out the back! I've always liked the way GKULLS Vette looks from the back with his 3's sticking out. JIm :cool:
Old Aug 3, 2002 | 04:45 PM
Twin_Turbo's Avatar
Twin_Turbo
Default Re: HELP! (PROSOUTH)
I got stainless steel dynomax race mufflers, only drawbakc is the oval input pipe wich needs some fabrication to adapt to my 3" round pipes.
I realy like the borla's but couldn't resist these for the money, if I didn't get this deal I'd have bought the xr-1s also.
These are the ones I have:
[Modified by Twinnie, 2:46 PM 8/3/2002]
[Modified by Twinnie, 3:18 PM 8/3/2002]
Old Aug 3, 2002 | 06:43 PM
danzig74c's Avatar
danzig74c
knalll !!!!!!!!!!!! :eek: :cool: :D
Old Aug 4, 2002 | 03:17 AM
JoeZ's Avatar
JoeZ
Twinnie...please contact me. ImAgE@zorsus.com
Old Aug 4, 2002 | 04:28 AM
Twin_Turbo's Avatar
Twin_Turbo
Default Re: HELP! (JoeZ)
You have mail
Old Aug 4, 2002 | 12:37 PM
PROSOUTH's Avatar
PROSOUTH
St. Jude Donor '05
Marck, Go to the Dr Gas web site, he has the adapter and pipe you need to hook them up. JIM
http://www.drgas.com :seeya
Old Aug 4, 2002 | 01:28 PM
Twin_Turbo's Avatar
Twin_Turbo
Hey thanks :) I love this forum :D
Old Aug 4, 2002 | 01:51 PM
PROSOUTH's Avatar
PROSOUTH
St. Jude Donor '05
DR. GAS OVAL TUBE SECTIONS, BENDS, & TRANSITIONS
MADE FROM 2" TO 5" DIA. TUBING
Our forming process produces perfectly shaped ovals and shapes transition tubes. They are free of pinches, buckles, and diamond shapes. Maximum cross section is maintained by stretching the tubing during forming. All tubes are made from Aluminum Killed Draw Quality (AKDQ) steel. This material is very resistant to cracking and splitting.
Oval Sizes Standard and Custom
Standard oval size made from 3 ½" dia. tubing is 2 ½" x 4". This size offer increased ground clearance with minimal loss of cross section. Dr. Gas can ovalize, including transition tubes to as thin as 1 ¾" inch for extreme ground clearance applications. Also, we can ovalize any tube sizes from ½" to over 6".
In 3 ½" tubing (NASCAR maximum), four different bend radii (center-line radius) are produced, ie" 3 ½" (1D), 5 ¾" (1 ½"), 7" (2 D), and 9" (2 ½ D). These tubes are offered in any shape from round, oval, straight or in bends up to approx. 110 degrees. There are to many to list here. Please call for any application. (801) 563-1111
BALL AND CONE ADAPTER JOINTS. These clamp together joints can be used in almost any location in the exhaust system. These are great to install near the mufflers in conjunction with headers. They make removal of the exhaust system for service needs a snap. With the two joint locations they are self aligning and are gasketless. 2 ¼", 2 ½" and 3" sizes are available. The 2 ¼" and 2 ½" sizes can be joined for a step in tube size at the joint.
Priced in pairs.
2 ¼" to 2 ½" - $42.95 2 ½" to 2 ½" - $42.95 3" to 3" - $59.95
REDUCER CONE HEAVEN. So many cones, so little time. Dr. Gas makes both long and short draft cones in many sizes. Ovalized cones are also available, as seen on our frame clearance tubes, and merge collector. To many to list here. Please call (801) 563-1111.
[B]I got to go shopping here soon..........................JIM]/B]
Old Aug 4, 2002 | 09:38 PM
PROSOUTH's Avatar
PROSOUTH
St. Jude Donor '05
Here's a pic of the BORLAs, There isn't really a 3 1/2" hole in it...........JIM
:yesnod: :lol: :seeya
[Modified by PROSOUTH, 7:44 PM 8/4/2002]
Old Aug 4, 2002 | 09:42 PM
Twin_Turbo's Avatar
Twin_Turbo
Damn those ARE nice
here's the pics:
You had spaces between the tags and the url :)
[edit] You were changing it when I was writing this :) [/edit]
Marck
[Modified by Twinnie, 7:44 PM 8/4/2002]
To HELP!
