Jumper cables were installed backwards and smoked something. Smoke came up near back of engine. Checked distributor and didn't see evidence of burnout but couldn't tell for sure where the smoke came from. Coil inside distributor has resistance across leads. Starter will turn over but engine will not start. Could it be the starter solenoid? Will it turn starter but not work properly for other wiring connections to the transistor module assembly? I'm hoping i didn't fry the TI module and coil.
Start by checking your fusible links. There are several. Smoke at the back of the engine could have come from fusible links down by starter.
Coil voltage is controlled by a resistor wire yellow/white cloth wrapped wire to + side of coil.
Look for the basics first make sure you have voltage at all the proper places first and no blown fuses.
I don't have TI but I beleieve that it is powered off the fuse panel via a add on lead ( similar to the way power windows are added at the factory) check that fuse in the fuse panel IGN. That lead will be plugged into one of those taps.
TI system gets its full 12VDC power off the pink wire on the steering column ignition switch, if your starter cranks you probably have power to TI Amplifier. This system is not fun to troubleshoot, I have a spare amplifier board as a " carry on spare " on any K-66 TI car that I travel with. There are upgraded TI amplifier poards being made, try Wilcox Corvette. You should have a GM service manual and a VOM meter to troubleshoot the K-66 system. I can easily envision a amplifier failure if you tried to crank the Vette over with the battery polarity reversed. TI specialties has a decent section on troubleshooting the K-66 system the GM manual is the best source.
Last week i ddn't even know what a TI ingition was. I was really surprised when i took the distributor cap off and started digging in to the issue. I was even more surprised when i found out how much this stuff costs. Really appreciate your help.
Thanks for the help. Also, it looked like the distributor shaft will have to be pulled to replace the coil inside the distributor and i wonder why they placed the amp inside the front left fender well. It looks like i will have to removethe light to get to it.
It looks like i will have to remove the light to get to it.
With the hood open, you should be able to get at it in the gap between the hood and the front fascia. I upgraded my Amp a few years ago with the new solid state module.
Getting the amp out was not an issue.
I removed the amp and took the cover off but frankly the electrical testing is a little over my head. I'm thinking about just buying a new circuit board along with a new wiring harness and magnetic pickup assembly pole piece for the distributor. Can I get a quote from you on these parts?
Also i would like to know if i can just pull the distributor as is without rotating the engine to TDC as long as i mark the locations well before removal?
It`s not cheap but if you or anyone else reading this is interested I have a genuine GM NOS (not the Chinese crapola sold these days) magnetic pickup pole piece in a sealed pull string box available, if you want to save some money I also have a repop center spool for the magnet available...my ti collection below.
Send the amp box to me, I can test it for you... and fix it if needed. If interested, email me at support@willcoxcorvette.com
