Performance breaks ..
Old Nov 30, 2014 | 09:34 AM
diehrd's Avatar
diehrd
Default Performance breaks ..
Has anyone used Aerospace Components brake systems ? ( rotors, calipers, lines ) If so how do you like them ?
Old Nov 30, 2014 | 03:10 PM
cardo0's Avatar
cardo0
From: Las Vegas - Just stop perpetuating myths please.
Well since i tore the fuel lines out of my vette im taking a "Performance break" myself. But i can still sit in the seat and make noises - oops i have the seat out too, never mind that.
Aerospace? I just want to drive on terra firma.
Old Nov 30, 2014 | 03:30 PM
cagotzmann's Avatar
cagotzmann
Originally Posted by diehrd
Has anyone used Aerospace Components break systems ? ( rotors, calipers, lines ) If so how do you like them ?
What tires are you going with. If you are not changing to any Ultra summer tires in the 17" 18" I would not spend a dime on anything other than the stock brake systems. Or if you do upgrade the kits should include ABS or I think they wont add much change vs stock. (maybe looks etc)
Here is my tests about a year ago.
https://www.corvetteforum.com/forums...8-results.html
Old Nov 30, 2014 | 05:14 PM
diehrd's Avatar
diehrd
You nicely pointed out a spelling error , and have no idea AeroSpace Components manufacture racing brake system.
Thanks for that ,,
I am not interested in pad performance just want to know if anyone has used the corvette system from aerospace components and apparently you both have not.
Old Nov 30, 2014 | 05:58 PM
C3 Stroker's Avatar
C3 Stroker
I wish they would have had a kit available when I upgraded my brakes (years ago). I see now they have kits for street vehicles......in addition to their "drag race only" pieces. I put together a Wilwood C3 kit similar to Aerospace's which works very well and costs a little less. This kit was offered by Precision Brakes, which later went out of business (?). Another forum member had Aerospace on his drag vette during that time and liked them, though they were not recommended for street driving.
I upgraded for weight savings only, but noticed extra stopping power on the street with my Wilwoods. The stock calipers weighed 13 lbs./ea. and the Wilwood DynaLites 4lbs./ea including pads.
Old Nov 30, 2014 | 05:59 PM
7t2vette's Avatar
7t2vette
The ORIGINAL and bestest
Toronto Events Coordinator
Oliver (GrandSportC3) had the kit on his old drag car; you should contact him for some real-world feedback.
https://www.corvetteforum.com/forums...van-steel.html
https://www.corvetteforum.com/forums...installed.html
Old Nov 30, 2014 | 06:19 PM
diehrd's Avatar
diehrd
Cool the set I am looking at are for the street. They have 3 options but I am not sure if the offer the rear set .. Which I am also interested in if they offer it
Old Dec 1, 2014 | 01:22 AM
cardo0's Avatar
cardo0
Well speaking of "Performance breaks" we havent heard from our favorite non-supporting vendor this weekend. Plenty of "what cam" posts on the forum too. Maybe theyre just setups for the non-supporting vender to show up and try to look good. Or maybe hes on a "Performance break" too. I read his business partner is posting but not with any cam advice - hmmm?
Ok your correct, i know nothing 'bout AeroSpace brakes. I can admit that. Just couldnt resist comment - timing is everything. Please dont shoot me. Good idea increasing your braking power now that u increased your hp with a new motor.
Good luck DH.
Old Dec 6, 2014 | 06:53 AM
diehrd's Avatar
diehrd
Good luck DH.
I have ordered the nickle plated brake set up for all 4 corners. I also went after the front control arms to rebuild them .. Junk .. So I ordered a set of TRZ motor sport control arms .
Breaks and control arms will add better driveability and cut 114lbs off the weight of the car.
I also have a much lighter hood and front bumper , deleted a/c , composite Intake and aluminum heads. Tubular cross member , composite rear spring and deleted the spare tire set up. Also bought new rims which are lighter. and a aluminum radiator.
I will try to weigh it all but I think a safe est of weight savings is 200 pounds mostly north of the center line of the car. I had no goal of weight savings but if I can get close to 3000 I would be pretty amazed
Old Dec 8, 2014 | 08:09 PM
cardo0's Avatar
cardo0
If your getting a weight reduction along with larger brakes it makes those parts a great idea. Had to look at those control arms and read they are 30 lbs lighter on the front - wish i had some. I assume your drag racing only as those control arms are designed for drag racing. Dont know how they would hold up on a circuit track - u would have to contact them.
Yes the front end is where the weight needs to come off. But the only other idea i can think of is aluminum driveshafts (custom). Have u considered a roll cage? If your going below 11 sec in the 1/4 u will need a 5 point. A mech friend of mine says most of the vendor roll cages wont pass inspection due to irregular wall thickness. I heard the standard gauge tube has to many flaws and now custom tube is sought.
Old Dec 8, 2014 | 08:48 PM
diehrd's Avatar
diehrd
Actually I am a street car , and no doubt I will be in the 11's .. But it will be a one time run at Motor City .. I did place the order for the control arms , they are aware it is a street car and have no issue making them stronger for my application .. Like the brake people TRZ is very helpful.
I wish I had the actual curb weight to begin with but after I run down the track I will get on the scale and see where I am at.
Old Dec 8, 2014 | 08:56 PM
diehrd's Avatar
diehrd
thanks
Old Dec 8, 2014 | 10:22 PM
d555's Avatar
d555
About 6 years, look good work well as long as you change fluid on a regular basis. Every other year at a minimum.
I drag race as well as run mine a little on the street, but mostly to the track, home and to occasional corvette only show. When drag racing it's almost as much fun slowing the car down really fast at the end of a run as doing a burnout. Not quite but fun to hit the first return road with out having to turn out later. I really hate pushing the shute. Don't have a trunk, so makes it a bitch.
Came with 1/2" studs. Look good, work well. Not sure how much weight I saved as I never weighed the originals to compare.
Rears are original Delco Moraine's with Hawk HP+ pads. Willwood Adjustable proportioning valve. The front spindle covers are threaded on and have a thin O-ring to seal out dirt. Can be tough to remove if not lubed before installation.
If I used a larger wheel, not sure if I would buy them. I'd go with as big a rotor as the wheel allowed... but if weight savings are what you are looking for? What the hey, it's only $$$
Dave
Old Dec 16, 2014 | 07:25 AM
diehrd's Avatar
diehrd
I will post pic and how easy/hard it all goes together
Old Dec 16, 2014 | 08:17 AM
GrandSportC3's Avatar
GrandSportC3
Cruise-In IV-V-VI-VII-VIII Veteran
St. Jude Donor '03, '06, '17
thanks
I had the aerospace drag brake kit in front and rear from VAN STEEL.. The reduction in rotating mass knocked over 2 tenths off my 1/4 mile time at the drag strip.. However, I don't think that the drag brakes are really designed for the street.. Break performance of the drag kit is not at the same level as the one for the street.. So, unless it is car that is mostly used for racing, I would recommend going with the street version of the kit.
Old Dec 16, 2014 | 09:24 AM
diehrd's Avatar
diehrd
That is what they are building me .. Street for 4000 pounds or less ..
Old Dec 16, 2014 | 12:40 PM
GrandSportC3
That sounds good.. Those brakes also look very sharp...
To Performance breaks ..
