2 or 4 bolt main.
Old Dec 3, 2014 | 11:28 PM
CVO2FIXUP's Avatar
CVO2FIXUP
Default 2 or 4 bolt main.
I have a stupid question because I am a newbie. I have a 71 LS5 is it a 2 or a 4 bolt main? Thanx.
Old Dec 4, 2014 | 09:48 AM
Alan 71's Avatar
Alan 71
Hi CVO,
I don't know if there's a consensus.
From what I read it seems like the majority have 2 bolt main bearings but certainly some have 4 bolt main bearings.
I think it's one of those things that for most people matters more in their brain than in their engine.
Regards,
Alan
Old Dec 4, 2014 | 09:52 AM
carbster09's Avatar
carbster09
Alan,
Funny, ... I am sure I knew if my '71 was a 2 or 4 bolt main at one time! I seem to have forgotten. Now where is that engine build sheet??
Damn thing runs fine either way!
CC
Old Dec 4, 2014 | 09:58 AM
Jbster's Avatar
Jbster
Most LS5 engines had 2-bolt mains. Only way to know for sure is to drop the pan.
Old Dec 4, 2014 | 10:27 AM
Tom454's Avatar
Tom454
My 70 LS5 numbers matching block pan is off right now... 2 bolt mains. Mains #3 and 4 have the (4) standoffs for the oil screen.
Old Dec 4, 2014 | 10:39 AM
joewill's Avatar
joewill
I have seen published that all factory installed 1971 ( and 1970 ) LS5 engines were 2 bolt. Someone convince me of an exception?
Old Dec 4, 2014 | 12:26 PM
Jbster's Avatar
Jbster
https://www.corvetteforum.com/forums...ne-thread.html
Old Dec 4, 2014 | 05:09 PM
CVO2FIXUP's Avatar
CVO2FIXUP
So, is the "larger threaded fitting" right above the oil filter the 100% telling sign weather you have a 4 or a 2 bolt!!?? If this is the case, then telling them apart is supper easy. Is this always the case though? (Bigger fitting on the 4's that is.)
Old Dec 5, 2014 | 02:55 PM
tracdogg2's Avatar
tracdogg2
512 block yes
289 block sometimes
445 and 959 block no
Old Dec 5, 2014 | 03:02 PM
63mako's Avatar
63mako
St. Jude Donor '08-'09
I have seen a numbers matching 4 bolt main L48. The line had to keep moving and the workers were not all veterans. If the wrong block went on the line or if supply was low hard to tell what went in or why.
Old Dec 6, 2014 | 12:19 AM
CVO2FIXUP's Avatar
CVO2FIXUP
Originally Posted by tracdogg2
512 block yes
289 block sometimes
Are these numbers part of the block stamp? How do I know what I have? Where do I look to see if these numbers corespond to anything on my car? Thanx.
Old Dec 6, 2014 | 12:29 AM
CanadaGrant's Avatar
CanadaGrant
I have a 69 L36 427/390 with the original engine. It has never been rebuilt or out of the car. It's a 3968512 block and is 4 bolt. I removed the pan and timing cover to replace the pan gasket and was shocked. I understand that there was a strike or something and parts were used as they had them at the time.
Block is T1020LM on the stamp pad.
Old Dec 6, 2014 | 12:41 AM
hwcoop's Avatar
hwcoop
Regards,
Alan
Just use ARP Main Studs and Rod bolts for extra reliability
Old Dec 6, 2014 | 11:54 PM
CanadaGrant
I don't use anything. I figure that after 45 years, the original stuff is probably going to outlast me....
Old Dec 7, 2014 | 06:52 AM
L88Plus's Avatar
L88Plus
Those are the last 3 digits of the block casting number. It's on the ledge at the back of the block on the driver's side, just in front of where the tranny and block meet.
To 2 or 4 bolt main.
