1973 l-82 roadster engine refresh
Old Dec 4, 2014 | 04:43 AM
Dan Klaiss's Avatar
Dan Klaiss
2nd Gear
Default 1973 l-82 roadster engine refresh
Am doing an engine refresh on my 1973 l-82 roadster. Am installing a comp cam high energy 274 cam, brodix k-180 aluminum heads, weiand dual plane intake etc. My question is are 2 and a half inch exhaust adequate or should i switch to headers, not sure. Thanks for any insights
Old Dec 4, 2014 | 06:46 AM
7t9l82's Avatar
7t9l82
headers will allow everything to work together much better. the more power an engine makes the more headers will help. so yes, you would be leaving a fair amount on the table without headers .
Old Dec 4, 2014 | 09:40 AM
jb78L-82's Avatar
jb78L-82
Unless you plan to race the engine, 2.5 inch ram horn exhaust manifolds will be fine with a good flowing 2.5 inch dual exhaust with free flowing mufflers for a normal street car.
Old Dec 4, 2014 | 02:14 PM
Solid LT1's Avatar
Solid LT1
Headers will give a 20HP or larger increase in performance. Since you went with aluminum heads, I'll take it your not interested in keeping the car in original condition. Going from a set of highly ported early C2 fuel injected 2.5" rams horn manifolds to a set of 1.75" headers on my LT-1 dropped the drag times by 4 tenths of a second and added 4 MPH to the trap speeds with the same mufflers and exhaust system being used. You would definitely feel the difference!
Old Dec 4, 2014 | 05:02 PM
jb78L-82's Avatar
jb78L-82
Here is the dilemma: I achieved 233 RWHP with a totally stock L-82 except 2.5 duals, free flowing mufflers, shorty headers-Thee engine was rated at 220 Net HP (OEM stock) with 2-1-2, 2.5 exhaust, restrictive mufflers, big restrictive cat which is about 180-185 RWHP when totally stock. Removing the RAM horns, cat, and adding 2.5 duals, with free flowing mufflers, shorty Headers added roughly 45-50 hp, roughly 180-185 RWHP to 233 RWHP. I have a very hard time thinking that LTH's would have added much beyond that improvement on a stock type engine. Maybe on a big build HP engine >450 HP but I am not convinced it would be over 10-15 HP-just not so sure....
Old Dec 4, 2014 | 06:35 PM
AirBusPilot's Avatar
AirBusPilot
Keep in mind those single exhausts they put on cars back then, with that convertor, were EXTREMELY restrictive. I totally believe you can pick of big power just by running duals v. the factory single cat system. Real headers on a stock L82 are probably worth another 20 hp, with a nice bump in midrange torque.
To 1973 l-82 roadster engine refresh
