Exhaust system?
Old Aug 4, 2002 | 10:35 AM
ashy22's Avatar
ashy22
7th Gear
Default Exhaust system?
Hi Guys
OK I have a problem. My 1971 454 LS5 coupe is fitted with hooker headers with a 3" collector flange. The rest of the system needs replacing due to rust holes - it is a 2-1/4" pipes and standard muffler setup.
Should I fit a chambered system (if available for mating to headers) like the ones from MAD :D - they sound good, or would it be better to fit a hooker exhaust system and a pair of their aero chamber mufflers for easier fit.
Has anybody tried these combinations or have any experience of it.
I am in the UK so all parts will have to be shipped in from the states and these bits are heavy :(
Thanks in advance
Paul
Old Aug 4, 2002 | 12:21 PM
trw's Avatar
trw
Default Re: Exhaust system? (ashy22)
First welcome to the shark pond. You live on the other side of the pond. :D
Either system will be the same to install. It depends on what you like. I think the chambered are louder. I have heard that they resonate inside and are more restrictive than good mufflers.
At least, if you go with mufflers, you could change the sound by swapping mufflers.
Listen to some other BB's and see what you like.
Terry
Old Aug 4, 2002 | 12:29 PM
PRNDL's Avatar
PRNDL
Default Re: Exhaust system? (trw)
I would go with a 2.5" aluminized (or stainless if you like that and can afford it) exhaust that allowed for high performance mufflers (as recommended above). You will need elbows to accomodate Flowmaster or similar type mufflers. The front pipes will also need to be cut to fit the headers. Aren't there shops that could make up exhaust pipes for you? Then you would only need to import the mufflers. Maybe you could find some Rolls Royce mufflers that would fit? :lol: MJ
To Exhaust system?
