Vertical Gate shifter..
Old Aug 4, 2002 | 03:27 PM
BB wowbagger's Avatar
BB wowbagger
Default Vertical Gate shifter..
Is anyone using the Vertical gate shifter in their vette?Any comments on its performance? :smash: :cheers:
Old Aug 5, 2002 | 11:28 AM
427Hotrod's Avatar
427Hotrod
2020 C2 of the Year - Modified Winner
2020 Corvette of the Year (performance mods)
C2 of Year Winner (performance mods) 2019
2017 C2 of Year Finalist
Default Re: Vertical Gate shifter.. (BB wowbagger)
It's going to require major console/tunnel mods to use one. It's a hardcore racing type shifter with "inline shifting" no H pattern.
I've used them on the street before, but they aren't really made for it. To downshift you have to lift the trigger to get back into the 1-2 gate.
But going up through the gears they are pretty good. BUT, you must make sure that everything is PERFECT on them. Don't take any chances... they aren't very forgiving. I had a good friend buy a used one and it was always having trouble dropping into the 3-4 gate when upshifting. It had a weak spring. He managed to find 1st gear while heading for 3rd while on the track. This was in a 10 sec. car that pulled huge wheelstands. He found first and literally spit trans out onto the ground and the flywheel exited out the firewall.
Great drag race shifter when set up right, only for street if you are a die hard!
JIm
Old Aug 5, 2002 | 01:03 PM
BB wowbagger
Default Re: Vertical Gate shifter.. (427Hotrod)
Aha,so it has the same pattern as a "rally tranny",just to pull/push it in to gears? :confused: :cheers:
Old Aug 5, 2002 | 02:20 PM
Wrencher's Avatar
Wrencher
Yea, it's the same pattern, just "vertical". From first it goes straight back to 2nd, then as you push forward, it slides down a ramp to 3rd, then straight back to 4th. Pain in the derriere for the street. I think you will find that the best shifter by consensus is the Hurst Competion Plus. No mods, and a great shifter.
Hans
Old Aug 5, 2002 | 03:04 PM
BB wowbagger
Default Re: Vertical Gate shifter.. (Wrencher)
Thats sounds a bit "overkill" for street use :eek: ..How about the Hurst shifter,does it out perform a good stock shifter ?Are the "throws" shorter or longer then the stock? :cheers:
[Modified by BB wowbagger, 8:06 PM 8/5/2002]
Old Aug 5, 2002 | 04:02 PM
Wrencher's Avatar
Wrencher
Very positive shifts and just a bit shorter throws. Overall an excellent shifter (the Hurst, I mean!).
Hans
[Modified by Wrencher, 2:04 PM 8/5/2002]
To Vertical Gate shifter..
