Hello Folks, I'm trying to figure out what the rear gear ratio is in my 1970 Vette. I cleaned it off a little bit and found these numbers. Can anyone interpret them or do they identify the ratio. This first set of numbers is inscribed in the bottom edge of the bottom bolt flange.
I believe what I can tell is: 1 CAV 4 24 70 W. the 2nd digit might be a G instead of C. Then, cast into the diff housing on the right side bolt flange just forward of the fill plug I found this letter/number: C240. It might be O240. Do these help to identify the diff and the ratio. Thanks, Dave.
If you have the car up in the air high enough to read the bottom of the diff then turn a wheel one turn and count the revolutions of the driveshaft, a piece of your kids chalk helps as does the kid to climb under there and help. BTW a "CAV" diff started life as a 3:08
If you have the car up in the air high enough to read the bottom of the diff then turn a wheel one turn and count the revolutions of the driveshaft, a piece of your kids chalk helps as does the kid to climb under there and help.BTW a "CAV" started life as a 3:08
AND....Being so old...ASSUMING that in the cars life the gear has not been changed.....which occurs.
Yep, thanks. I did count the driveshaft turns to one rev of the wheel. For years I thought this thing had a 3:36 gear. But in counting it today I got to 3 turns of the shaft and then when the wheel got back to its one turn starting point the shaft did not make it to even a 1/4 turn more. I thought, hmm, that ain't .36. Did it again and came up with the same thing, just a smidgen past 3 turns of the driveshaft. That's when I started looking for numbers. Started thinking it must be a 3:08. Just looking for confirmation now. Thanks again.
I'm going to put a new engine in this winter and needed to know what I was working with. Dave.
If I remember right I believe I am turning about 2700 rpms at 65mph. I had a formula for rpms to mph but I might not have written it down right. It was: Mph = tire dia x rpms / axle ratio. If I transpose that for axle ratio it would look something like this:
axle ratio = tire dia. x rpms / mph. but no matter what I plug into those values it doesn't come out right. So skip that idea.
I'm thinking it is a 3:08 now too. But here's another brain teaser. If you turn the wheel one revolution and count the turns of the drive shaft, that seems to work with a posi. But if you do that with a non-posi it doesn't work. It doesn't come out anywhere near right. What gives? Dave.
Your issue in your equation is that you didn't include a conversion factor for the units. The formula is mph = (rpm * tire dia")/(trans * axle * 336). For fourth gear calculations trans = 1.
Also, if you spin the driveshaft (instead of turning the tire) and count the turns for one rev of the tire it should work no matter posi or not.
For example, my '68 turns 3,000 rpm at 60mph with stock diameter tires........that would equal about 3.36 gears.
It takes slightly less than a 23" diameter tire for 3000rpm @ 60mph with a 3.36 rear gear. The stock tire on a '68 was an F70-15 or 205/70/15 which has a nominal 24.68" diameter. Assuming stock tires you should be 65.56 mph @ 3000 rpm.
As a reference a 255/60/15-27 inch diameter tire-which was a stock tire size beginning in the mid 70's with 3.70 gears and a 4 speed-1:1- will turn 2,860 RPM at 60 MPH-this information is from Road and Track-1978.
No guessing: Go to tirerack.com, put in the tire size you want, click on Specs, and this site will give you the tires overall diameter, as listed by the the tire manufacturer. I chose 255/50/17 ZR's when I changed rims since I wanted the exact same diameter of the 17's as when I used the 255/60/15-27.1-since I had 3.70 gears out back. Fronts are 255/45/17 ZR's-26.1 overall diameter.
