Wysco Radiator Hoses
Old Aug 4, 2002 | 08:47 PM
Wrecked82's Avatar
Wrecked82
Default Wysco Radiator Hoses
Anyone using Wysco steel radiator hoses?
Why did you go to Wysco - looks or cooling performance.
Advertisements seem to be for the top hose only. If you use on the lower, do you need the spring also?
Old Aug 5, 2002 | 08:55 AM
Red73's Avatar
Red73
Default Re: Wysco Radiator Hoses (Larry82)
I have CoolFlex hoses on my car and yes I did it for the looks! Rod
Old Aug 5, 2002 | 09:04 AM
GrandSportC3's Avatar
GrandSportC3
Cruise-In IV-V-VI-VII-VIII Veteran
St. Jude Donor '03, '06, '17
Default Re: Wysco Radiator Hoses (Red73)
I use those hoses on my 68! I didn't see a big difference in cooling. However - you can't beat the looks and durability!!
:cheers:
Olivier
Old Aug 5, 2002 | 09:29 AM
Fevre's Avatar
Fevre
I used universal hosee that look similar to the stainless steel ones pictured above but are ribbed rubber with built in/molded in steel coils to prevent collapse. Less than $10 a piece.
[Modified by Fevre, 7:29 AM 8/5/2002]
Old Aug 5, 2002 | 10:41 AM
Wrecked82's Avatar
Wrecked82
Default Re: Wysco Radiator Hoses (Fevre)
[QUOTE]I used universal hosee that look similar to the stainless steel ones pictured above but are ribbed rubber with built in/molded in steel coils to prevent collapse. Less than $10 a piece.
QUOTE]
Can't beat that price. Where did you get them?
To Wysco Radiator Hoses
