68 big block starter problems
Old Dec 11, 2014 | 09:17 AM
Davpmars's Avatar
Davpmars
Default 68 big block starter problems
I have a 68 with a 454 big block (originally a 427). About 6 months ago it made a horrible sound so as I inspected and, long story short, i needed to replace the starter. This starter was an aftermarket mini-high torque starter and I decided to replace it with an original.
The new starter seemed to be working great. It had a loud winning sound on crank but i figured that with no grinding noise, the sound was probably just the way those original starters sounded.
The other day I went to start it and there was a horrible grinding noise. I thought maybe a bolt came loose again. Nope. Tried to start it again and that grinding noise came again. I pulled the starter and sure enough, I'm grinding the flywheel teeth.
After some research I have come to realize that the winning sound on crank is because the pinion was too far away from the flywheel. The problem I'm having is that I never used any shims but it seems I'm still not close enough to the fly. How do I fix this problem? Everything I've read suggest taking out shims but there are none to remove, the starter is snug right up to the block.
Old Dec 11, 2014 | 11:46 AM
MelWff's Avatar
MelWff
I believe you can accomplish that by inserting a partial shim on the outside bolt only that will angle the starter closer to the flywheel or the starter nose is incorrectly machined.
http://www.marinemechanic.com/site/page169.html
Old Dec 11, 2014 | 01:38 PM
Ironcross's Avatar
Ironcross
Never use shims, it places the starter AWAY from the flywheel, not closer....a little known fact is that the starter almost always stops in the same position .........Cranking attempts just make it worse and you probably should fix the problem with either a ring gear if 4 speed or a flex plate if a automatic
ring gears are about 20 and flexplates 30
nothing wrong with the starter either
but whatever
Old Dec 11, 2014 | 02:00 PM
Scottd's Avatar
Scottd
This may be a shot in the dark, but make sure you are using the correct SAE bolts. I had a small block that I installed a mini starter in. Every few months the bolts would back out and the starter would jump around, even cracked the nose once. Come to find out I was using metric bolts. They thread in just fine but had a taper on the top that was bottoming out in one of the blind holes. The SAE bolt was flat topped and allowed for proper torque. Just a shot in the dark.....
Old Dec 11, 2014 | 05:15 PM
Davpmars's Avatar
Davpmars
but whatever
Can you be more specific? I don't see how a ring gear will help in this application. And as far as my flywheel goes I really don't want to have to remove the flywheel, that would require removing the engine in my case.
Old Dec 12, 2014 | 07:29 PM
Ironcross's Avatar
Ironcross
Because your ring gear is causing the problem....its worn out...and you will have to remove the flywheel and put a new ring bear on it....the pictures confirmed my replyr
Old Dec 21, 2014 | 08:44 PM
sumcollegekid's Avatar
sumcollegekid
I had a similar problem with my 1969 427. The only way to get rid of the sound was to replace both the flywheel and replace the gear on the starter. I installed it with no shims and it works like a champ.
Definitely a PITA to have to pull the tranny, but it worked.
Sum
Old Dec 23, 2014 | 09:06 AM
68notray's Avatar
68notray
I don't see the pics but in my experience , shims are NEVER needed. Unless you've alteted something a GM starter will bolt to a Chevy block and align to a GM flywheel every time. It does however sound like you need a new ring gear. If it is a manual at least you could flip it, but still gotta come out...
Old Dec 23, 2014 | 02:29 PM
Samason's Avatar
Samason
Experienced this with my 68. It's the teeth on the flywheel ring gear, as stated above.
Mine was caused by the previous owner installing the shims. The 327 had the starter bolting on vertically, but I thought the 454 was the horizontal (modern) style bolts?? Regardless, I would not recommnd shims. Shims will only make the problem worse (which was also stated above).
I pulled the engine and replaced the flywheel. Yes, I could have replaced the ring gear, but for me it was simpler to replace the flywheel. It wasn't bad. Pulled the engine on Friday, put it back on Saturday, drove it Saturday evening.
Good luck!
Old Dec 23, 2014 | 04:08 PM
Davpmars's Avatar
Davpmars
I did finally fix my problem. The teeth on the Fly were not so torn up that I couldn't continue to use them. Just a small portion of the tip of the teeth had been torn off.
I was able to add about 140 thousands of an inch in half shims to the outside mounting bolt which tilted the motor towards the Fly just enough to make a good tight connection. My car now sounds better than ever when cranking.
Old Dec 24, 2014 | 06:56 PM
Ironcross's Avatar
Ironcross
The engine still stops in the same position however...And you could have broken the nose
Old Dec 24, 2014 | 09:29 PM
68notray's Avatar
68notray
Yikes. I know sometimes you just gotta do what you gotta do....but I would think you may be doing more harm. The starter endures a crapload of force and now its cocked in there. Might shear off a bolt or worse. I would fix it properly with a new flywheel or a better rigged idea might be to have a machine shop mill an eighth off the nose housing - but then in the future it'll need shimming if you ever change the flywheel. .010" or .020" under 1 bolt maybe but .140" is a HUGE number IMHO.
Old Dec 24, 2014 | 10:56 PM
W.B. @ Bama's Avatar
W.B. @ Bama
Reman starters from NAPA state that a min. 8,9, volts measured at starter while cranking. If you have a voltage drop, the solenoid will not fully engage. If you add shims it will only add to the problem.
To 68 big block starter problems
