Master cylinder upgrade?
Old Dec 13, 2014 | 09:37 PM
BlackC3vette's Avatar
BlackC3vette
Default Master cylinder upgrade?
A little chilly today, but a nice day, I took the 80 for a ride. Returned to the garage and popped the hood to adjust the choke. I noticed the master was leaking some fluid from the rear of the cap. I took the cap off and cleaned up the gasket and the mating surfaces. The master is the original which has the normal dis-colorization from being the original master and I thought about replacing the cap with a chrome one, but then I would have a chrome cap on a crappy looking master. So what's the most popular upgrade? A new master and paint it before installing or buy a chrome unit?
Old Dec 13, 2014 | 09:47 PM
7T1vette's Avatar
7T1vette
Your original master cylinder is a MUCH better piece of hardware than any aftermarket parts "knock-off". You can buy a rebuild kit for your M/C and it will be good-as-new. A good rebuild kit will cost about the same as a complete 'new' () M/C; but the end result will be much better if you just rebuild what you have. I would suggest getting the rebuild kit from a NAPA store.
P.S. The rebuild kit has a new set of valves, springs, and seals/gaskets in it. As long as you don't find any significant pitting in the valve bores, it should be fine. You may find some minor rusting/light-pitting, but using some crocus cloth to clean that up should do the job.
Old Dec 15, 2014 | 12:55 PM
Roozstr's Avatar
Roozstr
A brake cylinder hone works great for cleaning that bore up. Got one in my tool box.
Old Dec 15, 2014 | 01:47 PM
MelWff's Avatar
MelWff
if it is only leaking from the cap, replace the cap gasket. With careful masking you can paint the master in place to make it look new again.
Old Dec 15, 2014 | 02:54 PM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Originally Posted by MelWff
...if it is only leaking from the cap, replace the cap gasket...
That's what I'd do.
Old Mar 12, 2021 | 09:55 AM
NRAROX's Avatar
NRAROX
How do you 'apply' crocus cloth to such a small space? Wrap it around a dowel or some other cylindrical object? My cylinder has some surface discoloration and some very, very small pits. I'm hoping to clean it up.
Thanks for your help.
Old Mar 12, 2021 | 03:47 PM
Cmurray79's Avatar
Cmurray79
I agree, get the ac delco master cylinder for reliability. But for looks and a little bit of weight savings, there is this one...
https://www.jegs.com/i/JEGS/555/631000/10002/-1
I intsalled it not too long ago, no leaks and it fits well.
Old Mar 12, 2021 | 06:59 PM
vettebuyer6369's Avatar
vettebuyer6369
You are answering a post from 7 years ago. Consider asking your question in a new thread.
To Master cylinder upgrade?
