Radiator Tie-Through Mounts?
Old Dec 13, 2014 | 10:24 PM
Factor's Avatar
Factor
Default Radiator Tie-Through Mounts?
hI all!,
since I am having issues with clearance to my BB radiator to front sway bar, AND will be going electric fan...any ideas on low clearance with HIGH CFM...???
found the flex412...but it has those 'tie-through' mounts holding to the radiator cores...I am not a big fan, especially on a new alum radiator, but it seems like the only option...thoughts?
thanks,
Ron
Old Dec 13, 2014 | 10:36 PM
Mooser's Avatar
Mooser
Just out of curiosity, what's the issue with the swaybar? (or the rad)
For the record I run the dual SPAL with home made brackets (same Z bent shape as most)
M
Old Dec 14, 2014 | 09:40 AM
jb78L-82's Avatar
jb78L-82
I would not use radiator ties through the radiator-just asking for leaks. Don't ask me why I know-not on my C3 though….
Old Dec 14, 2014 | 10:03 AM
Willcox Corvette's Avatar
0Willcox Corvette
Former Vendor
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
Originally Posted by Factor
hI all!,
thanks,
Ron
Hi Ron-
I'm not sure what radiator you are using or if you have a stock sway bar but you could have a issue with one or the other based on what you are running.
There are aftermarket radiators on the market place that do not have the clearance in the lower hose neck required to clear the factory sway bar. The lower neck should have a indentation in it for the bar to clear and without it, you'll never get the radiator in the car.
The lower neck should be a swooping curve vs. a a 90 elbow too.
Willcox
Old Dec 14, 2014 | 11:25 AM
Factor's Avatar
Factor
I agree on the NO zip ties...but hard to fit...
Got these sway bars...
http://www.zip-corvette.com/catalog/...it-front-rear/
Radiator
http://www.zip-corvette.com/catalog/...inum-radiator/
installed the sway bar with outside ends, below (in height) from the main bar between frame rails. DRAWING
ALSO pics of my setup...
Old Dec 14, 2014 | 11:31 AM
0Willcox Corvette
Former Vendor
The rad is Tom Dewitt's so it should be good to go. The sway bar looks fine as well.
Is the lower neck hitting the say bar?
Old Dec 14, 2014 | 12:02 PM
Mooser's Avatar
Mooser
Pretty much looks like my setup, how thick is that fan setup your trying to fit in there?
M
Old Dec 14, 2014 | 10:57 PM
Factor's Avatar
Factor
the lower neck seems fine. havent put the hoses on yet...but should be ok.
the issue is how close the sway bar is to the radiator, WITH the angled and closer proximity to the radiator...the sway bar comes up 3" from the bottom of radiator AND is 3.5" between BOTH...(small picture)...
the 3300 cfm electric one i got was 4.1" and sat 2" above the top of the radiator...so I am searching for high flow/cfm, with less than 3.5 clearance/depth OR shorter in overall height...thinking 16.5 inches depending on structure...???
for a BBC pushing 550hp...thinking minimum of 2000 cfm?...
Old Dec 14, 2014 | 11:21 PM
Mooser's Avatar
Mooser
Here's a link to the dual spal measurements
https://www.a1electric.com/spal/specs/30102052.pdf
Also, since they are not as tall, you can mount them higher so there is only brackets at the bottom
These are my brackets (test fitting) but they mimic the images I've seen from vendors
I'll see if I have one with the bar in place
M
Old Dec 14, 2014 | 11:55 PM
0Willcox Corvette
Former Vendor
Okay.. I'm out.. you follow Mooser he'll get you straight..
Willcox
Old Dec 15, 2014 | 08:38 AM
Mooser's Avatar
Mooser
Took a couple of shots of the area (ignore the dirt)
I've actually got less room on the spreader bar than on the swaybar.
Anyway, HIH
M
Old Dec 15, 2014 | 01:47 PM
Factor's Avatar
Factor
WOW mooser! very cool!
Wilcox thanks for the help!
Mooser...like your brackets...got another pair available ? super sharp!
Old Dec 15, 2014 | 03:50 PM
The13Bats's Avatar
The13Bats
Zip ties through the radiator are very bubba shade tree cheesy.
2000cfm...no, try about 3500 for that kind of HP
Like the spals mooser is using or the flax a lite 410 skinny fans 480 more cfm thick fans but but suppose to fit a c3 I plan to run it with my 454,
Mooser you sb or bb?
Old Dec 15, 2014 | 05:24 PM
Mooser's Avatar
Mooser
Dewitts did offer their brackets separately but when I sent emails they didn't bother answering so I bent up my own out of some stainless sheet I had leftover from another project.
2000 cfm should be tonnes with the alum. rad. Lots of guys running lots of HP with single 16" SPALs which are only around 1900cfm.
M
Old Dec 15, 2014 | 06:42 PM
The13Bats's Avatar
The13Bats
M
I am in orlando florida, I have a mild-ish 454 and will run ac and have auto tranny,
I will not take a chance with a 16" when that big black magic fan wouldnt even keep my 86 c4 cool stuck in traffic on a hot day....
I guess I am not as lucky with you on cooling.
Old Dec 18, 2014 | 09:20 AM
70BBvert's Avatar
70BBvert
I have Addcos 1.125" sway bar, the same Dewitts radiator with dual spal fans and the frame brace on my 70 454 also. Everything fits wits with no interference.
Why not contact Dewitts regarding their dual fan set up or the new brush less fan set up
http://www.dewitts.com/collections/s...brushless-fans
Jim
Old Dec 18, 2014 | 02:24 PM
The13Bats's Avatar
The13Bats
Jim that is sweet,
I believe I would have a single tear run down my cheek drilling the mount holes in the radiator for the fans....
Which spreader bar is that, I copy yours I know it will fit...
Old Dec 18, 2014 | 05:49 PM
70BBvert's Avatar
70BBvert
Jim that is sweet,
The spreader bar is from Vette Brakes, the fan & radiator came assembled from Dewitts. about the tear
Jim
To Radiator Tie-Through Mounts?
