Red Hot: Spirited driving = melted hose!
Unfortunately, I think I got too spirited because I apparently melted a vacuum hose! Well, not me, but the hot exhaust manifold melted the hose.
As I got off the freeway at the end of my, ahem, spirited drive - I smelled something burning. Uh oh. So when I got home a few minutes later I popped the hood (in the dark) and something was glowing! Yeah, that's a new one.
So what is it and what's it for? It's on the passenger side of the engine, coming from the carburetor I believe (I only did a brief visual inspection - it was cold and I was hungry) and down to a diaphragm near under the manifold near the dipstick.
1980 Corvette (non-CA originally)
350 crate engine
A thing I learned in military aviation is to do a "walk-around".....
(take a look at the vehicle/aircraft to see if everything is O.K.)
Sometimes we can spot a potential problem.....it's not an easy habit to get into, but it pays for itself the first time we "stop a gremlin" from causing a part-failure on our "ride".
If you're not an NCRS "kind of" guy, you could put a metal tube in that area with a radius-bend in it to give clearance around the E-manifold/connect the rubber hoses to each end of the metal tube to prevent future "glow-in-the-dark-problems....LOL.
Doesn't seem like that should have gotten hot enough to burn given it's distance from the manifold.
No vehicle and especially one of our beloved C3's should suffer the fate of an underhood gasoline fire due to gasoline vapors escaping their protected path.
To the OP, please let us know what solution you employed to prevet a repeat of your picture taking. Looks too close for comfort.
That is the vacuum line to the heat riser valve, which in 1980 was operated via vacuum instead of the thermostatic coil. 1980 corvette vacuum systems are clearly not my strong suit, but I would expect that vacuum line to becoming from some sort of temperature vacuum switch, possibly on the intake manifold or water outlet. It helps your motor warm up faster - part of the emissions system.
That routing is curious - between the exhaust manifold and the A.I.R. tube. But, like I said, I am not familiar with 1980 corvettes.
Well, I was interested to see how that is supposed to run. It looks like it is supposed to be tubing that is held away from the exhaust manifold via a clip that is supposed to be at the valve cover bolt. Here is a link to a picture on Paragon's website.
https://www.paragoncorvette.com/c-23...ilterID=23582&
About two years ago I kept smelling gas but couldn't find the source, until I looked under the hood while the engine was running and saw gasoline leaking from the fuel pump. I immediately bought a fire extinguisher and drove (puckered) to my mechanic.
http://www.semasan.com/page.asp?content=aa_2012CA4&g=SEMAGA
Good to know, thanks for the heads up - I'll check it out.
