Using a pertronix coil
Old Dec 18, 2014 | 08:58 PM
ozzyrulesme's Avatar
ozzyrulesme
Default Using a pertronix coil
Can I use a pertronix flame thrower coil with stock points in my 74 l-82? Would it hurt anything? Or should stick with a acdelco coil.. Thanks!!!
Old Dec 18, 2014 | 10:59 PM
Mooser's Avatar
Mooser
I left my flamethrower coil on when i removed the pertronix unit, never got around to putting the delco back on. Ran with no issues for a couple of summers.
M
Old Dec 18, 2014 | 11:11 PM
Mike Ward's Avatar
Mike Ward
You can, but it won't make any difference in performance.
Old Dec 19, 2014 | 10:37 AM
7T1vette's Avatar
7T1vette
Not really. The stock points, stock coil, and the ballast resistance built into the vehicle wiring all work together to set up proper ignition spark. If you just mess around with one or two pieces of that system, you won't gain much...and could end up frying points much more quickly.
Old Dec 19, 2014 | 12:30 PM
Mike Ward's Avatar
Mike Ward
The common myth is that a hotter spark somehow causes the engine to produce more power. It doesn't. The fuel/air mixture either ignites or it doesn't. The stock coil does an excellent job.
Old Dec 19, 2014 | 05:36 PM
gcusmano74's Avatar
gcusmano74
I can tell you this:
The stock coil ran fine for nearly forty years.
I replaced it with a Pertronix coil, which only lasted six months.
Now, I have another stock coil.
Old Dec 19, 2014 | 07:23 PM
ozzyrulesme
Thanks for all the in put. Just cleaning up the engine and my buddy had a new chrome one the at he said I could have. Not sure how old the acdelco is.
Old Dec 19, 2014 | 10:31 PM
CanadaGrant's Avatar
CanadaGrant
I'm using a Petronix in my 69 big block but have swapped stock coils with theirs and changed back and forth to points with both and find that the coil is just a gimmick. A stock coil will work just as well and so will theirs.
Use the one you have.
Old Dec 20, 2014 | 12:02 PM
69427's Avatar
69427
From: I tend to be leery of any guy who doesn't own a chainsaw or a handgun.
I'm still running the original '69 Delco coil (hooked to an HEI module instead of points) in my car. The original coils are a lot more robust and dependable than aftermarket coils.
Old Dec 20, 2014 | 12:28 PM
Peterbuilt's Avatar
Peterbuilt
Is there any way to test for
A - a good coil
B - if one might give more out put than the other?
Old Dec 20, 2014 | 12:42 PM
74modified's Avatar
74modified
A - a good coil
http://www.aa1car.com/library/ignition_coils.htm
To Using a pertronix coil
