TH400 Not Downshifting
I have a 72 coupe with an auto transmission that will not down shift. This is a fresh build with 50 miles on it. Shifts great other than when I go to get on it. I can manually down shift and it works fine. I've confirmed that I have good vacuum to the modulator valve. The modulator valve is new as well. Here is my question. Is there some kind of electrical switch that does this operation? I see there is a 2 prong switch on the Lt side of the trans. I also see there is a switch on the accelerator. Neither are not hooked up currently. Is this the switch or actuator to down shift the transmission? If it is... Is there a separate harness that runs from the accelerator switch to the transmission? I don’t see either switch in my wiring schematic and I don’t have any wire connectors unhooked in the vicinity of the switch on the accelerator. I should tell you that the car has all new wiring as well. Not sure that matters...
On the firewall side, I do have a 2 blade connector with a tan / orange wire that is not hooked to anything. This would be close to the accelerator switch. Again not sure if it actually goes to anything on my car. This aftermarket wire harness seems to have some additional connectors that don’t get used. I don’t know how it would go through the firewall anyways since there is only approx 6-8 inches of wire exposed from the loom or harness itself.
Any guidance you can provide would be awesome!! I just recently got my vette on the road from my lengthy 16 year restoration. The car runs and drives great so far, just need to figure out the transmission issue!!
A pretty common problem is the connector not being all the way in on the trans (or falling off completely)
Maybe start there and work your way back.
The switch at the accelerator is fed by the tan (one of them) right back to the main fuse block.
HIH
M
OH
This diagram is from the chassis manual for the kickdown and is confusing since they show two separate tan wires connecting to the TCS solenoid and then connected together. The solenoid connections are both #141, they are actually the same (one single) wire. but that shouldn't affect your kick-down in any way shape or form.
M
You should actually be able to hear the trans solenoid click (if your right under there with the engine off and someone trips that switch, of course a test light is better but....
M
Inside the trans (mounted with 2 small bolts to the underside of the valve body [channel plate] assembly), there is a solenoid valve which, when activated, dumps pressure and causes the downshift. That solenoid valve could have failed...or be plugged with 'gunk'; or the feed wiring to the trans or inside it could be bad; or it could just be that it isn't hooked up at the accel pedal.
Good luck with your diagnosis and with your repair.
The top pic certainly looks like the one for the switch on the accelerator
But as you say, it's on the wrong side of the firewall.
I'll see if I have any pics of where it came through, it came through the hole right beside the throttle cable.
Do a continuity test between that plug and the one for the trans.
Worse comes to worse, pull the wires out of the flat plug and pass them through the grommet and re-install on the inside
M
Last edited by Mooser; Dec 25, 2014 at 12:28 PM. Reason: Found out where it came through on my firewall
As for the different gauge wire, I imagine there is some difference as I have replaced every wire harness in the car.
Thanks for the help!!
