WANTED: CHEAP HP SECRETS
Old Aug 5, 2002 | 09:31 PM
Corz's Avatar
Corz
Cruise-In IV Veteran
Default WANTED: CHEAP HP SECRETS
I'm going to be racing another forum member in a month (on a track) and i wanted to get some secrets for more ponies.. here are my specs
327 +.030
10:1 CR
64 cc 1.94 heads
.445/.465 lift cam (220* duration i think)
edelbrock performer intake
holley 600 vac secondaries carb
dual point dist
TH 400 with shift kit
posi rear with 3.08s
what can get me a little higher in the hp department ?
Old Aug 5, 2002 | 09:42 PM
Matt Gruber's Avatar
Matt Gruber
Default Re: WANTED: CHEAP HP SECRETS (Corzvette69)
Nitrous
Old Aug 5, 2002 | 09:50 PM
gearheadz's Avatar
gearheadz
Default Re: WANTED: CHEAP HP SECRETS (Matt Gruber)
Nitrous
Ditto...best HP for the buck! Roughly $2-3 per horse with a basic plate kit.
Old Aug 5, 2002 | 10:04 PM
Mike69@ECS's Avatar
0Mike69@ECS
Former Vendor
Cruise-In III Veteran
Cruise-In V Veteran
Default Re: WANTED: CHEAP HP SECRETS (mdsmith)
Spray it! You know you want to! :D :yesnod:
I'll let you install my kit if you'll paint hot licks on my truck!!! :smash:
Oh yeah... who are you racing?
Old Aug 5, 2002 | 10:32 PM
QuickVet's Avatar
QuickVet
Default Re: WANTED: CHEAP HP SECRETS (Mike69)
you dont need hp. you need to take off the sway bar, let the tire pressure out, run on an 1/8th tank, get 90/10 adjustable shocks, empty out your glove box and practice your Reaction time :)
Old Aug 5, 2002 | 11:34 PM
GrandSportC3's Avatar
GrandSportC3
Cruise-In IV-V-VI-VII-VIII Veteran
St. Jude Donor '03, '06, '17
327 +.030
10:1 CR
64 cc 1.94 heads
dual point dist
Cheap?? Break into a Speed Shop and steel a supercharger.. The maximum it can cost you is a couple of years in jail :jester
Just kidding - couldn't resist!!
On a serious note: As mentioned before - NOS is for sure the biggest bang for the buck - however - it involves some risks too!!
Sometimes it's wise to invest some money and get the car dyno tuned. A well tuned car can produce a lot more HP than a not all that well tuned one... Another - not too expensive way to get cheap horsepower is to remove the mechanical fan and install a electric fan. You can get decent electric fans for $100 - $150.... Depending on the type of mech. fan you are using - you can get up to 10 extra HP... If you have regular 1.5 rocker arms - switch to 1.6 ratio roller rockers (if your springs can handle the additional lift). You can get good roller rockers for less then $200 and they can produce a couple more horsepower than the stock oned...
:cheers:
Olivier
[Modified by GrandSportC3, 10:35 PM 8/5/2002]
Old Aug 5, 2002 | 11:49 PM
Indy Year 25's Avatar
Indy Year 25
Default Re: WANTED: CHEAP HP SECRETS (GrandSportC3)
And grab some go fast decals! :lol: :lol:
[Modified by Indy Year 25, 10:49 PM 8/5/2002]
Old Aug 5, 2002 | 11:52 PM
73 LS-4's Avatar
73 LS-4
Have you recurved the distributor yet? Drop as much weight as you can.
:cheers:
Pat Kunz
Old Aug 6, 2002 | 12:52 AM
Markm10431's Avatar
Markm10431
Parrothead
St. Jude Donor '08-'09,'13, '14
get free flowing cats and mufflers, or ditch em completely
Old Aug 6, 2002 | 01:11 AM
Stevo81's Avatar
Stevo81
I didn't know the words "cheap" and "horsepower" could be used together :eek:
Old Aug 6, 2002 | 01:51 AM
Corz's Avatar
Corz
Default Re: WANTED: CHEAP HP SECRETS (Stevo)
73-LS4, what do you mean by recurving the distributor?
Markm10431, no cats on a 69; besides I have headers and one hell of an exhaust.
Oliver, i believe 1.6 rollers would be wayyy too much for those springs
QuickVet.... I dont want to go that extreme ( i am driving the car to and from the track that is 90 miles away)
Mike... NO NAWZ!!!
so as it sits, gut the car and get it tuned on a dyno.. ok.. any more suggestions ?
Old Aug 6, 2002 | 02:01 AM
joeveto's Avatar
joeveto
Cruise-In V Veteran
St. Jude Contributor
Sometimes, the cheapest horsepower can be found by removing the burden your current horsepower has to deal with. That is, GET RID OF THE WEIGHT! The more you remove, the better off you are.
Other ideas? Look for the parasitic drag. Change over to synthetic oil. This is a proven one. And don't stop with the motor. Swap out the differential fluid and tranny fluid. Also, throw in a windage tray and a crank scraper. This won't help your low end power, but up top, it can help.
Then there's the mental horsepower. Shorter gears are great.
And ask any fifteen year old with a Honda gleaming in his eye, spoilers, 8-foot suckers, spot welded out of sheet steel pirated from a junk yard, can be good for loads of mental horsepower. And K&N air filters should never be overlooked either. Those are good for what? 80 HP? At least? Yeahhhhh baby!
Also, if you can drive downhill, that can help too. :yesnod:
Old Aug 6, 2002 | 02:32 AM
Corz's Avatar
Corz
Default Re: WANTED: CHEAP HP SECRETS (joeveto)
well.. i always wondered how a picinic table would look on the back of a C3 :rolleyes: but as of about 20 minutes ago. i broke out the CC and ordered a (drumroll please) ROAD DEMON carb :jester this fool be goin down like white on rice.. I'll let ya know how it goes when i get it on there. i cant wait for this hehe
Old Aug 6, 2002 | 03:14 AM
45ACP's Avatar
45ACP
The 600cfm Holley you have now appears to be more than adequate to feed your 327 - http://users.erols.com/srweiss/calccarb.htm
Going to a larger carb with no other changes is not going to net you any more power.
Is there a problem with the current carb that leads you to believe that it needs replacing?
[Modified by 45ACP, 2:16 AM 8/6/2002]
Old Aug 6, 2002 | 03:52 AM
Stingy74's Avatar
Stingy74
Default Re: WANTED: CHEAP HP SECRETS (73 LS-4)
Dam rights! A 100 pound loss is similar to gaining 1/10th of a second. And 1/10th normally means one car length.
Old Aug 6, 2002 | 06:00 AM
Turbo-Jet's Avatar
Turbo-Jet
NAWS! :smash: Don't be scared. Just do your homework.
[Modified by Turbo-Jet, 2:00 AM 8/6/2002]
Old Aug 6, 2002 | 06:10 AM
OnlyC3-4me's Avatar
OnlyC3-4me
Take a few minutes to make yourself the better driver. Know your shift points by heart. 1/4 tank of fuel - max. Lose the spare tire, jack, and anything else that can be removed. Headlights should be down. A/C work??? If not, Yank the compressor!! Good luck. :cheers:
To WANTED: CHEAP HP SECRETS
Old Aug 6, 2002 | 07:53 AM
Matt Gruber
if it has a 2 bbl. the 4 bbl is a great idea.
Otherwise :U
see my tips in sig. for A/F and dyno tuning
Old Aug 6, 2002 | 12:06 PM
page62's Avatar
page62
3.70 gears. Much faster off the line! :yesnod:
Old Aug 6, 2002 | 01:28 PM
Corz's Avatar
Corz
Default Re: WANTED: CHEAP HP SECRETS (45ACP)
the carb that is currently on there has a problem staying in tune. if i tune the car on a nice calm day, no more then 4 hours later does it need to be tuned again. that is not something i want to keep. Everytime i do a pull past 5 grand, it begins to buck and stutter and basically not move. i bought the demon which even tho it is a tad bigger then the current holley, i can still lean it out a little bit.
so far what i have yanked is the following,
A/C compressor, lines and evap cooler
spare tire, jack, and tire iron
the system came out (just have stereo and stock speakers)
half of the interior is out.
i guess i dropped a good 200 lbs out of the car.. any more suggestions?
