Was this factory?
Here is a link to the diagram that shows all the components and there placement http://www.parts123.com/corvettecent...50g&ukey=13083
Ron
The aftermarket button on the lower cover is probably wired into the factory horn wire at the lower steering column connection.
Why? There is probably a failure in the parts in the column. People normally scared of the steering columns, and I don't blame them. What would the failure be.. possibly something as simple as the lower contact being broke or the upper horn contact missing the plastic insulators. (it may have been easier for the PO to just wire in a button where he did)
The upper contact had plastic rivets in it and when they break they will usually cause the horn to go of continuously.
On the other side is the lower contact, which can break or have something wrong with it.
Installed it looks like this.
This PDF will walk you through each of the parts step by step as well as get you to the turn signal switch. http://willcoxcorvette.com/repairand...lp.php?hID=313
This picture may help you figure out the issue.
I took apart the steering wheel until this point because then I need a steering wheel puller. The snap ring on the steering wheel bolt actually wasnt there either. Heres what behind it looks like if you can see anything missing there too. I cant move the steering column up and down either even after taking out the column lock. Maybe that is jammed.
Oh and that button that was not factory at all? there were 2 red wires that went up to the horns. Where you can see the green wire is cut is where a red wire was connected to each end of the green wire that was cut. (That is how the wire originally went right? I cannot find any pictures of that either.
And this last pic is up under my dash taken where my phone can get to it and not me. You can see 2 wires have been spliced into so I'm not sure if that has anything to do with why my horns do not work but definitely not factory and why Im trying to take apart my dash only to see what these wires are for. Help?
Use the lower illustration I posted above it will walk you through this.
Willcox
If I press the horn and there's power going to the relay then it's not an issue in the steering column at all is it..?
Unplug the relay, test the red wire for power. If it is hot, jumper this wire to the green and the horn should blow. This confirms that the system is okay from the relay to the horn and that the problem is somewhere between the relay and the upper steering column.
The wire inside the column (black) is not a hot wire, it is a ground which completes the grounding circuit for the relay. When the relay gets ground it will then pass voltage from the red to the green.
The bulk head connector is the fuse panel where the wires pass from inside to the outside of the car.
If I were you, and since there is already an aftermarket horn button mounted.... I would remove the lower column cover and see what wires were hacked into to make that button work. I'd un-plug that button and test to see if one of the wires pass's continuity to the lower contact. If it does then great, you'll need to find the break between there and the relay. But this circuit is pretty simple to figure out so don't give up.
Willcox
