Grease nipple plugged ? How does a zerk tool work
Old Aug 6, 2002 | 08:25 AM
RATT7's Avatar
RATT7
Default Grease nipple plugged ? How does a zerk tool work
I was greasing my 1980 the other day and noticed that one of the nipples has to be plugged because when I tryed to pump the grease it failed - it felt as though something was preventing the grease from being pumped in.
I noticed that their is a tool avaliable called " zerk tool " , it is used for removing and cleaning grease nipples. I have seen the tool and it looks like a 4 pointed star, but my question is how do you remove the grease nipple with this tool - any suggestions ?
Old Aug 6, 2002 | 09:23 AM
Tex71BB's Avatar
Tex71BB
Default Re: Grease nipple plugged ? How does a zerk tool work (RATT7)
No idea - most of the zerks I've seen have flats on them at the base so you can put a wrench on them (and then clean them with a piece of wire or something). Do your's not have the flats? If not, seems like you could use a Crescent wrench to turn it out. :confused: :confused: :confused:
Old Aug 6, 2002 | 09:59 AM
RATT7's Avatar
RATT7
Default Re: Grease nipple plugged ? How does a zerk tool work (Tex71BB)
I will have to have a second look at it again - although going on memory I dont see an opprotunity to user a wrench - I will check again and see if there is a flat portion that I can get a wrench on - I believe that the nipple is plugged and it is a matter of replacing it or unplugging it
[Modified by RATT7, 8:02 AM 8/6/2002]
Old Aug 7, 2002 | 08:34 AM
Big Fish's Avatar
Big Fish
Cruise-In 5-6-7-8-9-11-12 Veteran
A CI-6 Car Show Winner
Try putting a little heat on the bearing if you can do so without burning up anything, then force new grease in to purge out the old stuff. Probably not the nipple that's plugged.
To Grease nipple plugged ? How does a zerk tool work
