Looks like most 225/70R15 tires are for trucks or ATV's, and BFG TA's are overpriced.
I Do NOT want the optional 255/60R15 size either.
I was about to go with some Khumo tires with 85,000 mileage rating, but I have now read that due to tread pattern & possible rubber compound changes, they do not handle well on wet pavement & get only 50% or less of the 85K rated mileage.
I really liked the old Uniroyal Tiger Paw GTS white letter tires, but they are no longer made either.
Can anyone recommend a good and inexpensive tire in this size?
The Cooper, Mastercraft and M/T are all manufactured by Cooper Tire in Findlay, OH. I have a pair of RWL Mastercraft Avenger G/Ts on the rear of my C3. The front two aged GoodYear GT II's will be replaced in 2015.
All are minimum 'S' rated tires with good wear and wet/dry performance comparable (IMO) to the Goodyear GT II's they now replace.
BFG TA Radial RWL -Tire Rack (Your local BFG dealer will have access to these same tires.)
215/70/15 - $464 (four tires) (26.9" dia)
225/70/15 - $544 (four tires) (27.4" dia)
235/60/15 - $572 (four tires) (26.1" dia)
Why do Corvette owners feel the need to buy the cheepest possible tires for their car? It is now 2015, what do you feel is a proper price for a limited production size tire?
You mention Khumo tires and an 85k mile rating, the longer a tire will last (treadwear rating), the worse it will handle. Hard rubber doesn't handle well and is the reason sports cars come with soft tires.
Unless your car is a daily driver, how long will it take you to rack up 85k miles? Once a tire is 7 years old, whether it has 1 mile or 80K miles it's time to change them.
Keep your stock rims and stock sized rubber in storage for shows and 'invest' in a set of larger diameter rims and 'modern' low profile rubber. The car will drive, handle and brake like you have just done a major suspension and brake overhaul (although may be noisier than ideal on poorly surfaced roads)
THANKS!!
I run Yokohama Avid S/T P235 /70 R15 been super happy with them great cornering and overall traction I do not drive in the wet so can not answer that one fills the wheel well up nicely a slight rub lock to lock on the inside frame area at the back of front tires and not sure what your pocket book looking for Good luck on your quest.
Can anyone recommend a good and inexpensive tire in this size?t
THANKS!!
2 questions. Do you plan on driving your C3 85,000 miles? Do you drive it in the rain?
Thanks guys for your feedback on tires.
I think I may be going with the Mastercraft GT's. They are made by Cooper, they look fairly decent, and are not too expensive either.
I know you said "inexpensive"...Not normally said about a C3 item... Here's what I went with after trying Falken's... Michelin LTX M/S ...225/70 R15... They fill the wheel well, handle great in the rain (which I confirmed again Friday during a 50 mile highway trip) but are NOT inexpensive....
