My 1975 L82 has quadrajet #7045203 TS
engine is 355 with AFR 190 68cc heads &
Lunati 60103 cam.
It seems to starve for fuel at about 5000 rpm.
Should I change carb.
Thank You
Lunati 60103 cam.
Thank You
q-jet is more than adequate. Check for reasons for fuel starvation. Low float level, low flow from the pump, dirty sock filter in the tank etc.
Your Q-Jet is a 750 cfm carb, and will easily support a 355 engine through 7000 rpm. You have a fuel supply problem or a carb setup problem. You can also have timing/ignition system issues that can cause the symptoms of fuel starvation.
Typical issues that will cause the symptom you describe:
Inadequate total timing
Improper timing advance curve
Plugged fuel tank pickup sock
Kinked fuel line (at tank or at frame rail)
Plugged fuel filter
Inadequate fuel pressure
Low float
Incorrect primary jets
Jammed or damaged power piston
Incorrect secondary rods
Incorrect secondary airvalve spring windup
Ruptured choke pulloff
Incorrectly adjusted choke - secondary lockout not retracting
Improper throttle cable travel/adjustment
Incorrectly adjusted/damaged secondary linkage
The stock needle/seat as supplied in good quality rebuild kits will support engines through 500 hp as long as fuel pressure is in the 6-7 psi range. The "improved design" aftermarket press-in seats with the "popper valve" design is crap and will cause fuel starvation problems.
Radial shaft play at the bottom of the distributor is indicative of lower bushing failure. The play itself will not cause the problem you describe, but in order for the lower bushing to fail on an HEI, something had to go through the bushing to cause the failure. I'd be concerned about what it is that went through the bushing to cause the failure - where did the metal debris come from that trashed the bushing...? You may have something failing other than the distributor, which could be the cause of your issue. Cut your oil filter open and see if you have metal in the filter: If you have a cam lobe going bad, it will cause the problem you have, and it will shoot metal into your distributor shaft and trash the bushing...
