Used cam a bad idea?
Old Jan 5, 2015 | 09:37 AM
woolf708's Avatar
woolf708
Default Used cam a bad idea?
I am thinking of getting a used cam with lifters for my 79 L48 with 100k that I've had for about a year. The add states it has only 1500 miles on it from a T-bucket, "great condition, full synthetic oil with zinc" . The cam is a Comp cams #12-21 0-2. Looks to be an agreeable cam by the specs. He wants $60.
I only have a couple hundred bucks in my winter improvement budget.
The car runs ok for a 79 and I have other task$ to get done before spring.
Old Jan 5, 2015 | 09:49 AM
MrJlr's Avatar
MrJlr
I would not do that.....
Old Jan 5, 2015 | 10:00 AM
tonak's Avatar
tonak
Old Jan 5, 2015 | 10:01 AM
tyancey00's Avatar
tyancey00
I agree, bad idea. that is a ware in part and it is already worn in on a different motor... Just a cam will not make much difference.
Old Jan 5, 2015 | 10:27 AM
woolf708's Avatar
woolf708
My concern is how was it broke in. I'm starting to collect parts to add power. So far I've only picked up a very nice intake (Edlebrock 2101 $40). I guess I should wait and go all in for a rebuild next year. It is a matching block.
Old Jan 5, 2015 | 10:30 AM
REELAV8R's Avatar
REELAV8R
Nope, don't do it, even if it's free.
Roller cam I'd say maybe, not flat tappet.
That cam is too much for your L-48 anyhow given it still has stock heads and compression.
Old Jan 5, 2015 | 12:11 PM
woolf708's Avatar
woolf708
Thanks for the input. I'm gonna take a pass on it then. It's going to kill me, but I know better, I used to build large diesels.
Old Jan 5, 2015 | 01:25 PM
Scottd's Avatar
Scottd
Good decision....
Ive sold a few used cams in the past, but Ive always included the lifters, arrainged in order, with the purchase. Putting a used cam onto new lifters is inviting a disaster.
Old Jan 6, 2015 | 12:21 PM
mrvette's Avatar
mrvette
TWO true stories, years ago in my '72 Pontiac Lemans, I managed to find a scrapped '67 GTO, I swapped out the heads, cam to the 350 Pontiac block....it was a PONCHO engine, not a SBC.....put on a new timing chain, and never kept the lifters in order bolted it all together and it ran for another 200k miles total ~300k as a delivery vehicle for a torque converter shop some friends owned.....
Now we pass a few decades, and I had put a '89 roller/ZZ4 engine in my '72 here in Florida, well it was recommended I use a ZZ9 roller cam from TPIS, NEVER BUY THAT!@!! or anything from them.....crooks....at any rate, the cam ran fine with stock roller lifters for about a year, then the engine started a rough idle, I went ape trying to find it, as every once in a while it idled smooth as silk.....someone sent me a stock L98 cam, and it layed around almost a year before I finally installed it, looking for lower idle speed, and so was totally stone shocked that POS ZZ9 cam came outta there with 6 lobes wiped out lifters were fine.....I put the L98 cam in there and engine as been smooth as silk for some years now....go figger.....
Old Jan 6, 2015 | 04:33 PM
TheSkunkWorks's Avatar
TheSkunkWorks
From: Graceland in a Not Correctly Restored Stingray
Good decisions don't always feel so good while you're making them, but do pay off in the end.
Old Jan 6, 2015 | 07:02 PM
7t9l82's Avatar
7t9l82
if the cam is wrong for the application to start with its out. a flat tappet cam of either type must use the lifters that have mated to the cam and must be in the exact position that it was broken in with. hydraulic cams have been used for decades with few problems but they have their quirks.. some of the issues of late are a result of people not knowing the little details. and 60 bucks is ridiculous for an $80.00 product.
Old Jan 6, 2015 | 09:32 PM
woolf708's Avatar
woolf708
I live relatively close to Summit Racing, I'll probably get a new cam and lifter combo setup, chain and all.
Again I appreciate the advice.
Old Jan 6, 2015 | 10:35 PM
Indiancreek's Avatar
Indiancreek
If it's a roller I'd do it, flat tappet probably not.
Old Jan 7, 2015 | 08:22 AM
woolf708's Avatar
woolf708
Yeah, a roller is definitely in the realm of posibilty, I could do that. Maybe roller tip rockers too. Ahh yes where to $top. At 100k mi, I know I'll be doing a rebuild in the future.
Old Jan 7, 2015 | 10:32 PM
Plasticfreak's Avatar
Plasticfreak
No used cams!
Old Jan 7, 2015 | 10:49 PM
Indiancreek
I have used rollers that have been run before. Not had issues the flat tappets have wear patterns that the roller doesn't.
Old Jan 7, 2015 | 10:59 PM
Plasticfreak
I guess it depends if it's a person you know and trust with engines and knows what they are doing.........for me I don't like doing things twice..........happened too many times before! We all learn as we grow older!
To Used cam a bad idea?
Old Jan 8, 2015 | 05:45 PM
Silvertone's Avatar
Silvertone
Originally Posted by Scottd
Good decision....
Agreeing with the already matched lifter set idea. And of course it would somewhat lower the risk of failure to just get a new cam. And $60 is too much for a used stick. With that said... there is no problem putting new lifters on a used cam, people replace them all the time. I've transplanted a few back in the 70s and 80s, low budget days, and never a failure with stock spring pressure. Just mic the lobes for consistency first and use some Isky lube. What you can't do is put used lifters on a new or different cam. Flat tappets spin and mate to the lobe, if they're already mated to another cam they won't seat in right. No fear!
Old Jan 8, 2015 | 06:32 PM
7t9l82's Avatar
7t9l82
absolutely correct
Old Jan 8, 2015 | 06:41 PM
TedH's Avatar
TedH
It would be good to know the spring pressure that he ran with the cam/lifters. Remember, he broke the cam/lifters in with more than just that high zinc oil.
Assuming no damage AND he correctly labeled the lifters to each lobe, I would say go for it. However, if you are going to consider a new set of lifters, you are probably better off with a new bump stick.
Be sure that if you DO buy the cam with the matching lifters that you ALSO get a fresh set of valve springs with the appropriate spring pressure.
And, if you are going to replace the valve springs, you may also want to address some 'while you are at it...' items (valve seals, pushrods, rockers... etc.).
When I installed my new Crane Energizer 272-H10 back in 1999, I also had a fresh recon pair of 882 heads with new hardware. So, the whole pkg was broken in together.
