Lifting a C3
Old Jan 5, 2015 | 06:24 PM
Ghunt's Avatar
Ghunt
Default Lifting a C3
Can a 68 C3 be lifted safely from the rear spring attach point?
I would like to lift the rear end up from the center instead of one
side at a time.
Can this be done With out braking something.
Old Jan 5, 2015 | 08:32 PM
DucatiDon's Avatar
DucatiDon
C2 of Year Finalist (performance mods) 2019
2018 C2 of Year Finalist
Yes. Use a block of wood so you don't damage anything.
Old Jan 5, 2015 | 10:27 PM
Duane4238's Avatar
Duane4238
Been lifting my '72 that way for over 40 years, now, and haven't hurt anything. Just be careful and throw some jackstands under the frame when you get it to where you want it. Block the front wheels, too.
Duane
Old Jan 5, 2015 | 11:09 PM
Scottd's Avatar
Scottd
A small section of 4x4 placed on your jack pad works great. After a few times it will take the impression of the pad and it just fits perfectly. Its almost creepy the first few times you raise the car like this......it works so well you are just waiting for it to fall off. (It wont)
Old Jan 6, 2015 | 01:06 PM
gearbreaker's Avatar
gearbreaker
how about the front?
Old Jan 6, 2015 | 01:55 PM
MelWff's Avatar
MelWff
you have to be careful with the front so you dont push in the crossmember. You must use a heavy piece of wood/metal that stradles the full width of the crossmember front to back and applies the force to the front and rear edge not the center.
Old Jan 6, 2015 | 02:11 PM
mikem350's Avatar
mikem350
My exhaust pipes almost touch, so I slide the jack saddle in there and go for it. As said b4 chock front wheels and use jackstands!
Old Jan 6, 2015 | 02:13 PM
mikem350's Avatar
mikem350
Or left to right....
Old Jan 6, 2015 | 04:37 PM
Ghunt's Avatar
Ghunt
Thanks for all the responses.
I thought it might be OK in the rear in as the weight of the car is on the spring attach point.
George
Old Jan 7, 2015 | 12:14 AM
LT1driver's Avatar
LT1driver
with the above and been doing c2/c3 since 70 as recommended above. good luck.
Old Jan 9, 2015 | 12:32 PM
kdf1986's Avatar
kdf1986
If you have the room between the rear exhaust, and can fit a jack under the springs, then it can be done. I use a low profile lift jack, with a small piece of wood to help distribute the loading points and this works well for me. Then I can place my jack stands on the corners.
For the front I use a wood strip to go front to back across the cross member so that I lift from the frame of the cross member, not from the center of the cross member. Then I can place my jacks under the front jacking points on the frame.
kdf
To Lifting a C3
