TPI idle rough
Old Jan 6, 2015 | 08:00 PM
s6tyn9's Avatar
s6tyn9
Cruising
Default TPI idle rough
History...fuel regulator busted fuel flowing to the plenum causing cylinder 6 and 8 flodding, replace regulator diafram, now won't idle right. Tested the fuel pressure barrowed fuel pressure gauge from Aurozone not sure if gauge is working right coz during the initial fuel pump prime the reading beyond the gauge (110+ psi) is that normal? I don't think so...while on rough idle the gauge still reading 110+. Is too much pressure can cause the rough idle and also do I have a bad fuel regulator?
Old Jan 7, 2015 | 01:01 AM
dugsgms74's Avatar
dugsgms74
If the pressure is indeed 110+psi that will definitely cause a rough idle. Try a different gauge and if it still reads high replace the regulator and check for a plugged return line.
Old Jan 7, 2015 | 01:03 AM
Amorget's Avatar
Amorget
Too much fuel pressure can cause bad idle (too much fuel). Fuel pressure should be 45ish psi off and in the low/mid 30s idling.
Old Jan 7, 2015 | 01:35 AM
s6tyn9's Avatar
s6tyn9
Cruising
Yes indeed the return line is clogged with rust and other stuff right after the rail where the fuel hose connect to the return tube. So its clear now did put air to it and its clear. The idle still rough maybe I need to clean the injectors coz for sure that dirty stuff that clogged the return may have gotten into the injectors.
Old Jan 7, 2015 | 08:30 PM
s6tyn9's Avatar
s6tyn9
Cruising
After uncloging the return line and did another fuel pressure gauge test the remain 0 (zero) while cranking and want to start rough idle then died. is it a bad regulator?
Old Jan 7, 2015 | 10:38 PM
7t9l82's Avatar
7t9l82
remove and clean the I.A.C valve located on the bottom of the throttle body.
Old Jan 8, 2015 | 12:50 AM
Amorget's Avatar
Amorget
I'm not sure what the IAC has to do with fuel pressure.
Bad FPR, bad fuel pump or blocked lines would be the only reasons for 0 psi.
Old Jan 8, 2015 | 06:28 AM
7t9l82's Avatar
7t9l82
i thought the complaint was a rough idle. no the iac won't affect pressure.
To TPI idle rough
