1980 Corvette Volt Gauge
Old Jan 6, 2015 | 12:25 PM
doning's Avatar
doning
Default 1980 Corvette Volt Gauge
Hey Guy's. Please take a look at the RED line on this gauge. This is where my needle is when I drive my car. Does this look normal to you? My mechanic says it's fine but shouldn't be closer to the "13" mark? Thanks, Don
Old Jan 6, 2015 | 12:36 PM
MelWff's Avatar
MelWff
did your mechanic confirm what the voltage is with his own gauge? Normal is 13.8 for a fully charged battery up to 14.5 for a battery that needs charging.
Old Jan 6, 2015 | 12:56 PM
doning's Avatar
doning
No, he just glanced over and looked at it. So, your saying my battery according to this gauge is NOT charging? It wasn't in the red so I assumed it's okay too.
Old Jan 6, 2015 | 01:45 PM
JimLentz's Avatar
JimLentz
Mine is close to that high until I drive around a little while and the battery is "topped off". I think I am at 14.8 volts when the car first starts and 13.8-14 after I have driven it around a while. Verify the reading with a voltmeter.
Old Jan 6, 2015 | 01:51 PM
MelWff's Avatar
MelWff
Default Volts
As Jim noted you have to check it with an external voltmeter to determine if it is charging too much. How old is the battery?
Old Jan 6, 2015 | 02:21 PM
mikem350's Avatar
mikem350
If you do not have a digital voltmeter, get one at wallmart or harbor freight. You would know the answer to your problem in about 30 sec.
I like to see what the bat voltage is BEFORE starting. Like 12.5 or so. Good way to check calibration of the dash gage. Then the alternator should kick up the voltage ABOVE this reading to indicate that it is charging, and stay there. Volts will vary somewhat due to batt condition and temperature.
Above 15 V or so means there is an overcharging condition. Check grounds and terminals for looseness/corrosion first.
Old Jan 6, 2015 | 02:23 PM
doning's Avatar
doning
Brand new. Bought in August. It's an Interstate brand.
Old Jan 6, 2015 | 04:44 PM
MelWff's Avatar
MelWff
Default New Battery
New batteries fail too, get a voltmeter and check the system.
Old Jan 7, 2015 | 03:58 AM
7T1vette's Avatar
7T1vette
Measure the actual voltage with car running, no lights or accessories on, and with it already fully charged. If is measures around 13.5 volts, your car is fine...even if the gauge reads higher than expected. This would indicate that your gauge is innacturate and reading somewhat higher than it should. No big deal....
Old Jan 7, 2015 | 06:42 AM
doning's Avatar
doning
Okay, thanks everyone. I'll let my mechanic take a closer look at it when the car comes out in the spring. Just wanted to see what you guy's thought of it.
Old Jan 7, 2015 | 10:04 PM
briankeery's Avatar
briankeery
Mine does the exact same thing. When checked with a voltmeter as discussed, I'm right where I should be. Rebuilt my alternator two years ago, new regulator and diodes - no change. Gauge is merely reading 1 volt too high in my case. I've just learned to live with it. If as has been stated the voltmeter checks out, don't sweat the gauge.
Old Jan 8, 2015 | 06:50 AM
doning's Avatar
doning
Sounds good, thanks.
To 1980 Corvette Volt Gauge
