twitchy rear
Old Jan 6, 2015 | 08:32 PM
deet's Avatar
deet
Cruising
Default twitchy rear
I tried a search but I'm probably not using the correct terminology. The rear of my 75 seems to twitch to the right when I accelerate and then when I lift off the throttle the car pulls to the right. What is the most likely problem with the rear suspension? I don't have much experience with independent rear suspension.
Old Jan 6, 2015 | 09:00 PM
gcusmano74's Avatar
gcusmano74
You need to carefully check the rear suspension. Look for :
sloppy trailing arm bushings, loose or missing trailing arm toe shims, sloppy wheel bearings, worn U joints on the half shafts, loose wheel lug nuts, loose or worn torque control bushings on the nose of the diff., strut rod bushings, etc. Any metal to metal joint that shows a trail of rust is moving relative to the piece next to it. If one of the U joint caps has a rusty edge, or a bolt head somewhere that should be tight, for example, that could be your problem.
Bringing the car back to stock will improve things. Please don't believe those who say you need to reinvent the entire suspension of the car to get it to behave well. You can spend a bunch of money on your car, and it certainly will be different afterward. But it's not so easy to improve it.
Let the flaming begin.
Old Jan 6, 2015 | 09:09 PM
hugie82's Avatar
hugie82
It does sound like trailing arm bushings or hub bearings. Another sign of trailing arm bushing problems is the inside of the rear tires being worn. I have to do my 82 this winter and I'm not looking forward to it.
Old Jan 6, 2015 | 09:52 PM
doorgunner's Avatar
doorgunner
2026 Loser of the Year
No flaming here...(it also could be a worn-out "snubber bushing" that holds the front of the differential in alignment)...
remove only one trailing arm and rebuild it.....then drive the car and notice the difference----then you'll have the experience to rebuild the other arm twice as fast as you rebuilt the first arm!
Some members would suggest to remove the complete rear suspension and rebuild everything---that's good advice if you have a bucket of money and lots of spare time!
Old Jan 6, 2015 | 11:19 PM
Mike Ward's Avatar
Mike Ward
90% chance it's one or both of these.
Old Jan 6, 2015 | 11:41 PM
1974ta's Avatar
1974ta
Default Twitchy Rear
Check all the rubber bushings. Chance are very good that they all need replacing after 40 years if there was no previous work performed.
Before rebuilding everything get a dial gauge and begin checking the actual play in the trailing arm bearings and axles coming out of the differential too. If they are out of spec it may make sense to consider a total rebuild. The differential is likely okay as they have been known to go 300k miles with proper maintenance. Just read of a 66 that went that long.
Whatever you do with the suspension, it will need a 4 wheel alignment when you are finished.
I highly recommend an AIM that will illustrate exactly how the factory assembled everything. A lot of times things were not reassembled properly when previous work was done.
Start with the simpler things as door gunner suggested like the snubber. (No alignment needed there either) Strut arm bushings are one of the simpler items to R&R as well.
Bill
Old Jan 7, 2015 | 03:42 AM
7T1vette's Avatar
7T1vette
If your engine is essentially 'stock', then your explanation is likely one of those listed previously. If you have beefed up the engine to over 400hp, but you haven't really done anything to stiffen the drivetrain and rear suspension, then the 'twitching' you are experiencing might be expected for your car with WOT from a dead stop.
Old Jan 7, 2015 | 08:00 AM
L88Plus's Avatar
L88Plus
Check to make sure Miley Cyrus isn't a stowaway...
Old Jan 7, 2015 | 08:18 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
FWIW: have you had the alignment checked?
Old Jan 7, 2015 | 08:38 AM
deet's Avatar
deet
Cruising
Haha, that would be twerking
Old Jan 7, 2015 | 08:41 AM
deet's Avatar
deet
Cruising
Thanks for all of the advice, I'm sure that I'll be posting a lot more questions in the future.
Old Jan 7, 2015 | 08:31 PM
Jartanyon's Avatar
Jartanyon
Mine did that towards the end of last year. Upon further inspection, I found my trailing arm bushing was gone. A very fun job if you do it yourself...
Old Jan 7, 2015 | 09:35 PM
Gale Banks 80''s Avatar
Gale Banks 80'
Not knowing what condition Your Car is in I must assume very little has been done to the rear suspension of Your 75. That's makes every bushing 40 Years old. That puts me in the camp of removing the suspension and rebuild everything--- that's good advice if you have a bucket of money and lots of spare time. Ok well if You go to a Corvette Vendor and check the prices of Suspension Bushing Kits are they really that expensive ? Labor intensive yes, but its cold outside and this is the time to do these kind of things. When things thaw out and You go to get it aligned the alignment tech will thank You for making it all right.
Old Jan 8, 2015 | 08:56 AM
Tampa Jerry's Avatar
Tampa Jerry
Default Trailing arm bushing
I agree with Mike. I really think your problem is either trailing arm bushings or your shims have gone south. Just for fun, check your transmission mount. If you have to replace the bushings, use only rubber and not polly. My polly bushings lasted a few years and broke like glass. After researching polly bushings, I learned that this is not uncommon, especially with side pipe cars. Removing the arms is not a tough job unless the bolts and sleeve(s) are frozen. Good luck. Jerry
Old Jan 8, 2015 | 09:57 AM
tyancey00's Avatar
tyancey00
be careful... I thought I would replace the bushings in my trailing arms... I now have everything from the flywheel back out and in rehab!
Old Jan 10, 2015 | 11:41 AM
C3 4ME's Avatar
C3 4ME
LOL tyancey!! I'll put in another vote for trailing arm related. What you're decribing sounds exactly like what mine was doing when I had a bad bushing.
Old Jan 11, 2015 | 04:05 PM
deet's Avatar
deet
Cruising
Default update
I looked under the rear end and the previous owner has installed a composite monoleaf. It's possible I may just need a four wheel alignment. My new question is how do I check the trailing arm bushings to see if they need replaced? the pinion snubber bushings look good. I blew my stash buying the car and it's going to be awhile before the wife is okay with me dumping money into it I'd like to know for sure it's a bushing problem and not an alignment issue before I tell her I need money. I may wear the pants in the house but she wears the skirt and we all know skirt trumps pants.
To twitchy rear
Old Jan 11, 2015 | 04:35 PM
Robert Perkins's Avatar
Robert Perkins
Easy way to check, jack rear of car place on jack stands, grab rear tire and see how much play you have moving it fore and aft then up and down. I was having a similar problem as you and I found my TA arm bushings were shot and so were the side yokes. Also check the condition of all your rubber bushings. Best to have someone do the moving and you watch what moves under the car.
Old Jan 11, 2015 | 10:15 PM
deet's Avatar
deet
Cruising
Thanks for info. Probably a nube question but this is the first time I've dealt with IRS.
Old Jan 29, 2015 | 08:50 PM
deet's Avatar
deet
Cruising
Default update
Yup, bad trailing arm bushing on the drivers side. Good times.
