1981 Headers, Emissions System Delete.
Old Jan 9, 2015 | 11:10 PM
ZR1 Jordan's Avatar
ZR1 Jordan
1st Gear
Default 1981 Headers, Emissions System Delete.
Planning to Remove emissions system for installation of headers and Cat. converter delete. for true dual exhaust.
Engine is original to the car (190 hp - 4 speed)
Mild cam\lifters installed
Timing increased
So Question is: The Computer controlled Carb. and Distributor, is it worth getting rid of it? or Tuned for better performance?
Looking for a better sound (headers & exhaust) HP doesn't have to be too much of an increase.
How much power can the computer get from a tune?
What is the cost of getting rid of the computer system all together?
Old Jan 10, 2015 | 01:35 AM
Shark Racer's Avatar
Shark Racer
I'm not very well-versed in what kind of ECM tuning options are there for the electronic distributors. The carb AFR would be best tuned mechanically - by adjusting the secondary AF ratio.
Headers and exhaust will give a GREAT increase for that motor.
I wouldn't get rid of the computer system myself, but if you really wanted to, you'd need a distributor and carburetor. $400 is around where I'd guess the low side is, but the sky's the limit from there.
Old Jan 10, 2015 | 11:46 PM
qwank's Avatar
qwank
I'm running the stock carb, distributor and computer with long tube headers and side pipes.
Just make sure you put an o2 sensor bung in your new exhaust and you'll be fine.
There's no tune for these computers, it only controls the spark advance and the fuel trim at idle. The rest is controlled by the carb to old fashion way. So if you want to "tune" the carb you would do it like any other carb.
One thing you can do is set your initial timing to 14-16 degrees from the stock 6 degrees.
To 1981 Headers, Emissions System Delete.
