Door Key Code ??
Old Jan 16, 2015 | 10:54 AM
mwm3006's Avatar
mwm3006
Default Door Key Code ??
Purchased a 79 vette online and when it arrived it only had the ignition key. Can't lock car. Was hoping to call chevy house and give VIN# to get a key but NO. Every locksmith says they can't make a key. Was hoping to avoid having to remove door panels and go thru the hassle of changing cylinders. Any suggestions??
Old Jan 16, 2015 | 11:05 AM
MelWff's Avatar
MelWff
You already know the answer, you have to pull a door cylinder, sorry. What shape is the head of the ignition key square or oval? You tried inserting it into both door cylinders?
Old Jan 16, 2015 | 01:35 PM
BKarol's Avatar
BKarol
Square key= ignition
Oval= all others
Some thoughts:
1. Did you get any paperwork with the car. If they sent the dealer invoice look at the center and there is a space for Key Code nos. Might be written in or typed. Tank sticker might have them. The letter code for a 79 oval is "B". Got this from the judging manual.
2. Drive to a competent locksmith and have him make a key.
3. Bring in the glove box door with the key cylinder and have him make a key or bring in just the cylinder.
(Luckily never had to try it) http://www.chevelles.com/techref/glovebox.pdf
4. Your spare tire has a lock if he wants to work on that.
5. Any one in the neighborhood with another 78/79 or gm from that era. Their key might work.
Hopefully no locks were changed out.
Old Jan 16, 2015 | 03:37 PM
BKarol's Avatar
BKarol
I don't know when the change was made (perhaps 74?)but in 78/79 the oval works the doors, glove box, rear compartment & spare tire lock.
Old Jan 16, 2015 | 06:56 PM
DUB's Avatar
DUB
I AGREE...A COMPETENT locksmith can cut a key.
DUB
Old Jan 17, 2015 | 11:02 PM
mwm3006's Avatar
mwm3006
Called many locksmiths in Austin Tx and they all say they can't make one. Pretty sorry.
Old Jan 18, 2015 | 12:46 AM
Willcox Corvette's Avatar
0Willcox Corvette
Former Vendor
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
If you get the code off the cylinder any locksmith should be able to cut the key.
On the Corvette glove box and rear compartment locks... they won't have a code on them so you'll have to pull a door lock.
Old Jan 18, 2015 | 12:55 AM
doorgunner's Avatar
doorgunner
2026 Loser of the Year
While we're on the subject (kinda').......
Is the rear compartment lock on a 1968 convertible the same as the door locks (My project only has an aftermarket ignition/key)........?
Old Jan 18, 2015 | 07:20 PM
DUB's Avatar
DUB
YEAH...that is pretty sorry. Try someone who REPOS cars and trucks. often times they may need to make a key on the spot. If you do not want to remove the door lock cylinder to get the code.
DUB
Old Jan 20, 2015 | 12:25 AM
doorgunner's Avatar
doorgunner
DUB
Thanks...I'll remove the lock since the door is bare from being repaired/greased.
Old Jan 20, 2015 | 12:03 PM
69Vett's Avatar
69Vett
Corvette of the Year Winner 2017
2016 C3 of Year Finalist
I had ALPHA key in Austin cut a corvette key suppling them with key code only.
Alpha Key Lamar blvd. 835-2626 good luck.
Old Jan 20, 2015 | 11:19 PM
doorgunner's Avatar
doorgunner
Good to know....if no one around here wants to make a key, we can send them our locks and let them handle it.
Old Jan 22, 2015 | 08:47 PM
Cavu2u's Avatar
Cavu2u
I had a locksmith make a key for me once. She used a soft metal blank, inserted it, "read" the indents made, and cut a key that worked perfectly.
25 bucks.
To Door Key Code ??
