81-82 Oil Temp Gauge
Old Jan 18, 2015 | 03:16 AM
alconk's Avatar
alconk
Default 81-82 Oil Temp Gauge
Where should the oil temp gauge be reading at on the gauge. What is considered normal? Mine runs between the first notch and the 250 deg mark.
Old Jan 18, 2015 | 01:26 PM
jb78L-82's Avatar
jb78L-82
That is the range of my 81-82 oil temp gauge in my 78 where the clock used to be….installed in 1986…..normal
Old Jan 18, 2015 | 07:12 PM
alconk's Avatar
alconk
Old Jan 18, 2015 | 11:55 PM
7T1vette's Avatar
7T1vette
Most GM gauges are designed to have the needle straight up (vertical) when a system is operating properly. Obviously, there will be variation in either direction from that, but it's a good 'rule of thumb'. That allows you to quickly assess performance without having to actually read the dial.
Oil temps are better when higher than 180*F and lower than 250*F. But, synthetic oils can take a lot more heat (near 300*F).
Old Jan 19, 2015 | 07:34 PM
alconk's Avatar
alconk
Oh ok great thanks! Good info right there.
To 81-82 Oil Temp Gauge
