Trans to Engine install
Old Jan 21, 2015 | 03:33 PM
68RPOL71's Avatar
68RPOL71
Default Trans to Engine install
Can the transmission be installed to the engine and both be re - installed to the car mounted together (without danger of breaking the ears of the transmission?)
this is a 427, and 4 spd M21 trans.
thanks,
Old Jan 21, 2015 | 03:54 PM
madam's Avatar
madam
thanks,
Had no problem with my 383 stroker and TH350.
Old Jan 23, 2015 | 01:39 PM
dntoearthman's Avatar
dntoearthman
thanks,
I put a 427 & Richmond 5 speed in, just used an engine leveler to ease the install. You won't break the tranny ears.
Old Jan 23, 2015 | 07:09 PM
DUB's Avatar
DUB
I AGREE...I but the engine and transmission in as an assembly and have NEVER had an issue...and I also use an engine tilter also.
DUB
Old Jan 25, 2015 | 01:53 AM
martinsw's Avatar
martinsw
I also remove and install both as one unit. I wouldn't try it without using the leveler though...
To Trans to Engine install
