Steering Column swap
Old Jan 22, 2015 | 06:38 PM
jrdestar's Avatar
jrdestar
Default Steering Column swap
Im in the process of swapping my standard column for a t&t and i noticed the acuator rod for the ignition switch moves forward on the standard column when turning the key and on the t&t it moves back when turning the key.Is this correct and can i just plug in to it even though the two plugs need to be repositioned?
My cars a 73
Thanks,
john
Old Jan 22, 2015 | 11:31 PM
Haggisbash's Avatar
Haggisbash
The ignition switch for the T&T is different. They are on special for about 12 bucks from a site vendor at the moment
Old Jan 23, 2015 | 07:53 AM
jrdestar's Avatar
jrdestar
Thanks Haggisbash, I searched the venders and couldnt find the one your talking about. Any hints
Old Jan 23, 2015 | 05:52 PM
Haggisbash's Avatar
Haggisbash
Ecklers
Old Jan 23, 2015 | 06:55 PM
DUB's Avatar
DUB
IF I at least knew roughly were you live...I could tell you...so not knowing if you are in the US or not...it is hard to say. BUT...if in the US,,,.this switch is common and you do not have to order one and have it shipped in if you have a local parts house....such as Oreilly's, NAPA, GM dealer.
DUB
Old Jan 24, 2015 | 09:38 AM
jrdestar's Avatar
jrdestar
DUB
Thanks DUB,
I guess i will need to add my hometown on my profile. I am in Green Bay,Wi. and yes i am still peeved about the Game. But there is always next year!
Old Jan 24, 2015 | 11:40 AM
Jim Shea's Avatar
Jim Shea
There are unique ignition switches for the standard (non-adjustable) columns versus tilt and T&T columns. There is only one vehicle wiring harness so either switch (which is part of the steering column) has to connect to only one harness. That harness has two plastic connectors that plug into the ignition switch located on top of the steering column jacket down under the dash.
Yes, the two switches operate in different directions. When switching from one type column to the other, you will need to take the vehicle wiring harness with the two connectors and twist them 180 degrees to get them to plug into the new steering column ignition switch. After you twist them, you will find that there is only one way that both connectors plug into the switch.
Jim
Old Jan 24, 2015 | 02:40 PM
jrdestar's Avatar
jrdestar
Jim
Thanks Everyone, Thats the info i was looking for.
To Steering Column swap
