New Lift this week
Old Jan 24, 2015 | 11:34 AM
cobrachuck's Avatar
cobrachuck
Default New Lift this week
Its a Titan AF9000AF
Designed for 11" ceiling perfect for working on Vette's
220v 20 amp
Old Jan 24, 2015 | 11:41 AM
Jud Chapin's Avatar
Jud Chapin
St. Jude 15 Year Donor
St. Jude Donor '11 thru '25
Nice addition to your garage...
Old Jan 24, 2015 | 12:14 PM
7T1vette's Avatar
7T1vette
SWEET !!!
P.S. You're not in the market for a tri-power setup for the '66 GTO, are you?
Old Jan 24, 2015 | 12:23 PM
'75's Avatar
'75
That's the same lift I have, I wonder how I got by so many years without it!
Old Jan 24, 2015 | 03:40 PM
Calo69's Avatar
Calo69
St. Jude Donor '15-'16, '18
Only thing more impressive than the cars,lift and garage is the license plate.
Thank you
Old Jan 24, 2015 | 07:09 PM
OMF's Avatar
OMF
The lift was the best investment I have ever made for my garage....it's so much easier on the back
I sure hope you enjoy yours...
Old Jan 24, 2015 | 08:14 PM
cobrachuck's Avatar
cobrachuck
Thanks for the kind words worked on the RR emergency brake & rotor today MUCH EAISER with the lift
Calo69 I did not know where south east Asia was at that time
Old Jan 24, 2015 | 08:21 PM
Eddie 70's Avatar
Eddie 70
Ci 6, 8 & 10 Veteran
St. Jude Donor '05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15
Congrats on the lift. I would love to have one. Maybe someday I'll get to have one too.
Old Jan 24, 2015 | 08:56 PM
Duane4238's Avatar
Duane4238
Awesome lift and garage setup. I'd love one, but my garage floor is blacktop and I'd have to rip it out and have concrete put in. By then I wouldn't be able to afford the lift. Thanks so much for your service.
Duane
Old Jan 24, 2015 | 08:58 PM
Calo69's Avatar
Calo69
My pleasure, I know this is Corvette forum, but 1/4 mi. Which one wins?
Old Jan 24, 2015 | 10:27 PM
PDsVettes's Avatar
PDsVettes
Duane,
Instead of ripping out your whole garage floor, you might be able to rip out the appropriate size pad for the lift you select and pour a pad as suggested in this link:
http://www.mohawklifts.com/consumer/...eco_2-2010.pdf
Use these guidelines and get it OK'd by the mfg of the lift that you purchase. A lot cheaper than the whole floor of your garage. No shortcuts with concrete PSI, rebar and pad dimensions that are approved by your lift mfg. Safety first.
I have a scissor lift that works great. You can't walk under it but it does get the car a little over three feet in the air. And you can use the one I have on asphalt.
Old Jan 25, 2015 | 08:43 PM
cobrachuck's Avatar
cobrachuck
Calo69 between those 2 the GTO is faster however the 13 Grand Sport in the other garage will run off & leave them both in dust.
Duane you might want to look at a 4 post lift with what Patdown said.
Old Jan 25, 2015 | 09:06 PM
Jeff_Keryk's Avatar
Jeff_Keryk
Diggin' that 67 Goat. The 65 thru 67's were some of the best looking cars ever made. And they flew...
Old Jan 25, 2015 | 09:09 PM
Calo69's Avatar
Calo69
Thanks, best of luck and more garages to you
Old Jan 25, 2015 | 10:00 PM
Kris Tunetso's Avatar
Kris Tunetso
I'd love to have a lift in my garage. That's a nice setup you've got there.
Thank you
Most important thing said here.
Thank you, and bless you, soldier.
Old Jan 26, 2015 | 01:59 PM
Duane4238's Avatar
Duane4238
Cobrachuck,
I was thinking about a 4 post lift on my blacktop. It has 4" of binder and 1" topcoat. plus about 6" of packed crushed stone under all that. In the 25 years I've had the Vette parked on it, there are no tire marks where the car sits. I was also thinking of putting an 18" square of 1/4" plate steel under each post. I'd think that would more than sufficiently support the load. Any thoughts, guys?
Duane
Old Jan 26, 2015 | 03:19 PM
Calo69's Avatar
Calo69
Go for it, not aproffessional engineer, sure there are load calculations, but I used to set up scaffolding for masonry work up to about 5 stories on less base than that with no problems. Worst case if it sags dig four holes and pour concrete footings. Either way you got your lift. Good luck
Old Jan 26, 2015 | 04:09 PM
Gordonm's Avatar
Gordonm
Originally Posted by Duane4238
Cobrachuck,
Duane
Not an engineer but if your vette has not "sank" into it at all so far the extra weight of the 4 post lift under 18 inch square plates you should be fine. I had a 2 post lift now have a 4 post lift. Would not want to be without one now. You just get used to having one. Best investment ever
Old Jan 26, 2015 | 10:56 PM
cobrachuck's Avatar
cobrachuck
Duane
I like the idea of the 18" plates for support. The feet on the 4 post are good size 12x12", the lift guy had both sitting side by side & considered both, the 2 post was my choice.
4 post can be 115 volt.
To New Lift this week
