clock/Lighter/Courtesy fuse problem
Old Jan 31, 2015 | 03:10 PM
VETTE N ME's Avatar
VETTE N ME
Default Solved No More Short!!!!
Originally Posted by VETTE N ME
Well when I disconnected the other plug fuse was good. Plugged it back in an it popped the fuse. The antenna itself was unplugged. So there is a short in the wiring after the relay.
Well I got under the car and looked at the wiring for the antenna and look at what I found
GOT THE WIRES SEPARATED AND INSULATED AND NOW I HAVE A POWER ANTENNA THAT WORKS
Old Jan 31, 2015 | 04:52 PM
Jet Tech's Avatar
Jet Tech
Great work!
Glad it's resolved.
Old Jan 31, 2015 | 05:51 PM
briankeery's Avatar
briankeery
Excellent troubleshooting, one more thing off the list.
Old Jan 31, 2015 | 06:14 PM
VETTE N ME's Avatar
VETTE N ME
Originally Posted by Jet Tech
Great work!
Glad it's resolved.
Thanks!! It only took a couple days
Thanks!! Yeah now I got to figure out why my domelight is not coming on. I'll get it figured out
Old Aug 18, 2017 | 06:14 PM
VET*RRN's Avatar
VET*RRN
4th Gear
Default new antennae blown fuse
*********not an electrician************
Recently installed new antennae and wired the red to orange pwr & blue to the yellow. The black ground is not attached to anything. Problem?
The new antennae worked when everything was torn apart/disconnected. Now that I have everything back together my courtesy fuse continues to blow immediately.
I get I probably have to take all that crap apart again but can someone explain, in laymen terms, what I should be looking for as I unplug each system? Or whatever I need to do.
