76 350 w/ AT. Holly 650 carb. Had At rebuilt then lost 1st gear on rebuild; after warranty repair car will hesitate on acceleration from a stop. Ran fine B4 re-rebuild.
Runs fine otherwise-just the stumble from acceleration after stop.
Changed fuel filter; check fuel into top of carb.;linkage -all look good.
Is it possible the vacuum modulator on the AT is bad. I put 10#'s of vacuum on the line from the AT Modulator to the intake and have a small leak. Should this line hold a vacuum?
Thank you
