77 Engine Pic
Old Jan 29, 2015 | 09:39 AM
InfidelCorvette's Avatar
InfidelCorvette
Default 77 Engine Pic
Just wondering if anyone knows of any, or could take a pic of the front of the engine of a 77 or equivalent.
Mine is not right. Want to try and figure out what sorcery the PO cast.
Thanks!
Old Jan 29, 2015 | 10:33 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Define "not right." Why not post a pic of your engine and we can take a look at what you have?
Old Jan 30, 2015 | 07:28 AM
InfidelCorvette
Accessory are not where they belong. The power steering cap is < 1 inch from the bottom of the alternator bracket.
Old Jan 30, 2015 | 08:46 AM
sullyman56's Avatar
sullyman56
This pic was taken with my iPhone and this is a 77 L48 that's never been altered. Hope this helps.
Old Jan 30, 2015 | 11:07 AM
REELAV8R's Avatar
REELAV8R
Probably the belt is too long on the PS pump. Get a shorter one and it should change the position of the cap since the pump will not be rotated as far to tension the belt.
Old Jan 31, 2015 | 01:18 AM
Giant_Robot's Avatar
Giant_Robot
looks like the PO raised the alternator's height so you can actually take off that power steering cap without a fight.
Old Feb 1, 2015 | 07:34 AM
mds3013's Avatar
mds3013
The PS cap is difficult to access on mine also. If the PS belt is too long the PS pump pulley will contact the frame. A shorter belt makes the cap even more difficult to remove. mike...
To 77 Engine Pic
