My '72 is a manual steering car and I want to purchase a Borgeson conversion kit. What else will I need to purchase? I want to do the installation in a day so I want all the parts available at the same time.
My car is a 48 state L48 without AIR pump but it has two groove water pump and crank pulleys. One groove for the alternator and the other for the A/C compressor.
Not to hijack but I heard that you might be able to reuse the original on the Borgeson by grinding down the splines on the inside of the rag joint then putting in a flat spot, is this true?
Originally Posted by ignatz
I did not like the rubbery rag joint Burgeon supplied. I mated their half of the coupling with my half of the original and a new rag joint.
If your original is not in the best of shape you may want to purchase new. Apparently that is a quest of its own.
I assume you mean using the original coupling and grinding the input shaft of the Borgeson and not the rag joint. Sounds unsafe to me.
Splines on the rag joint would seem to defeat its purpose. So far as I remember there are none. Also I don't know how one could grind a flat on what is essentially a doughnut hole.
The Rag Joint has the same # of splines as the input shaft of the steering column and the input shaft of the steering box..... There is a set screw, 4 actually, 2 on each end of the rag joint that comes with the kit from Borgeson. The rag joint is very flexible when you consider installed "vertical" deflection, but when you consider rotational deflection it is very rigid. This is so the inputs from the steering wheel are transferred directly into inputs to the steering box while allowing variations in the angle of the box to steering column while absorbing vibrations. Pretty cool concept actually.
The directions state no to use the flat spot on the steering column shaft for the set-screw, but rather grind a flat spot where it makes sense to do so based on the alignment of the steering wheel once installed. If you use the flat spot as-is on the shaft, you may end up with a cockeyed wheel. Make sense??
The borgeson box doesn't have splines, engineered that way, and now my lower flange doesn't either, seems safer than the set screw method. Mine is held on much better than that lower piece borg sends out. By all means do what makes you feel safe, I have.
Yes, sorry... The rag joint "assembly" has splines The rag joint itself of course does not........ not sure why splines are such a bad thing?
First off I wasn't trying to offend you, it has nothing to do with the cost, look if you can save a few bucks, I'm all for it and please share the info so we can save some money as well, we all need these cars can make a man go poor. My concern is you are removing metal (the splines) from a steering coupler. Technically you are making the metal thinner that's why I felt it was unsafe.
Originally Posted by '75
Post 134, what is it you think is unsafe? Do you understand what I did? or is it that it didn't cost enough?
I have zero memory of what the Borgeson shaft looks like. It's completely covered up by the coupler and what's there are two set screws which go to what? Two flats? The 134 picture shows a flat and a groove (and states there is another groove on the other side?) but isn't that for a jeep box? I think the Corvette conversion is probably two flats and one of the flats would have to match the coupling clamp bolt or a groove would have to be hogged out of it. Seems like a lot of re-engineering if that is the case. And what you've described in the 134 post is not really apropos for the Borg Corvette box. Do I have that right?
On the plus side there's no room for the coupler to slide off the shaft no matter how it is attached. And the set screws are holding fine after a couple of years of use. The concern would be that the flat holds better and I would agree with that but it isn't needed based on the experience of many many other conversions..
Gentleman, Borgeson makes a solid Stainless steel, with bearings, U-joint to take the place of the normal rag joint. It's around 100.00 with shipping when I bought mine. It is wonderful. Just call Borg. it gets rid of all the problems that you are having or dreaming about, with the Rag joint gone. Gene
On the part of the coupler i modified, I removed only the splines and didn't take out anymore material than that, so I can't see how it's weaker than it was. Maybe I'm just cheap, but it was a good solution for me. BTW, I used a Jeep box, which has the same shaft as the Borgeson, 18mm dd. In the end all the mods we make weren't intended by the original vette engineers. Some are better, some not, and some just as good but different. I think any time we mod from original we assume liability for it, so I'll only do things that I believe are safe.
Hi, I wasn't responding to your post, sorry for the confusion. Didn't mean that splines are bad, they are great, but my steering box didn't have them and I needed to adapt the rag joint coupler to it, so I ground them out. I would not remove the splines from the column shaft, no need to.
Yep, just ordered one, less then $100 out the door for unpolished, can't beat that.
