Side pipe tubes
Old Feb 4, 2015 | 10:12 AM
Kryptonite's Avatar
Kryptonite
Default Side pipe tubes
I am having an issue replacing my muffler inserts.
There is some corrosion inside the tubes preventing me from seating the mufflers. Can only insert a couple inches and the stop. Any suggestions
Old Feb 4, 2015 | 11:31 AM
resdoggie's Avatar
resdoggie
Had a 1976 L-82, 4-sp
Royal Canadian Navy
Wire brush for a 3/8" drill and have at 'er or just a wire brush.
Old Feb 4, 2015 | 01:57 PM
bashcraft's Avatar
bashcraft
Remove the corrosion.
Old Feb 4, 2015 | 03:24 PM
rastafford3164's Avatar
rastafford3164
You could also bend the flanges in a skosh. Mine were rattling originally. Had to take the pipes back off and bend the muffler flanges out so they were tight enough not to rattle.
Old Feb 6, 2015 | 12:21 PM
Kryptonite's Avatar
Kryptonite
Default Side tube corrosion
Guys I bought 3 12` extensions and a 4` wire wheel. Used a power drill and cleaned the inside of the tube very well. Sprayed carb cleaner in and worked on them 30 minutes all came out very well. Tubes are hung and I am now DEAF. Dougs freeflow glass packs are ecking LOUD.
To Side pipe tubes
