Interior heat question?
Where in theory does the interior heat come from?
Obviously a warm engine bay will warm it due to convection.
But what is the main driver of hot cabins?
I am thinking it is the full exhaust sitting there...
would love some thoughts here...
I am assembling 69 vert 454 with sidepipes and am finalizing my insulation/sound deadener/heat barrier...but am very curious to what you all feel is the main driver that can be prevented...
thanks!
Ron
I think it's really a combination of both the compartment and the exhaust pipes.
St.Louis wouldn't have gone to the expense of installing the firewall blanket and jute insulation and also the foam tunnel collar if the heat from the compartment wasn't migrating into the interior. A pretty half-*** attempt to control the heat from the transmission was the use of loose jute on the transmission tunnel under the consoles.
I'm not sure if the rubber coated dense jute under the carpet was there for appearance, heat, or sound….. likely all 3. I think that's especially true for the forward foot well underlayment.
Regards,
Alan
The block and tranny probably hoover at 200 degrees but the exhaust manifolds are much hotter than that.
Another thing i noted on my '76 is the y-pipe and catylic converter are under the passenger seat - and after several miles the heat passes up into the cabin through the inboard seat mounting bolts... hotter than fire they get after an hour or so.
My solution was to fiberglass wrap the exhaust pipe back to the converter - minimizing the heat coming up through the seat mounting bolts.
Another task i recently did was to lay self adhering ceramic foil sheet on the hvac air handling box... the exhaust manifold is about two inches away from that box and without some protection the box would certainly absorb heat and warm the air you are trying to pass through the air conditioning evaporator.
over the years i have never lost the thought that the c3 corvette was a car designed in the north with miminal concern for how the car would perform down south. If the designers had to walk out of their office everyday into the blast furnace summer heat of Florida, Texas or socal - the car would have been designed differently and not suffer so badly from heat transfer into the cockpit.
It would take a full fledged attack against heat transfer to win the battle...
Fast forward 30 years-
I really have gotten sort of use to AC...
I wanted my restomod to be cool in more ways than just appearance!!!
Since the car was originally a Non-AC car- the Astro Ventilation ducting had to be dealt with. I am adding Vintage Air.
I didn't want any heat coming from the engine into the cabin.
Why? Even w/o heating by the engine when the ambient temps are in the 90's - that just won't be comfortable. On my daily driver - I'm always running the recirculate setting.
I fiberglassed up all the holes- and made a fiberglass piece to close off the Astro vents- then screwed the back flaps closed.
Coated the interior w/ Lizard Skin- and covered the exterior w/ Zero Clearance using 3M tape on the seams. I am also NOT running a heater-no heater lines- just don't need it down here- and if it does get cold- I have heated seats.
My thought were to reflect the heat AND insulate the cabin. If you look at duct work- the conditioned air is INSIDE the reflective exterior..and the space shuttle put the heat shields on the OUTSIDE of the spaceship. Air makes a great insulator - till it moves!!!
I haven't done any testing- who knows if it will make that big of a difference- BUT you might was well do it right -considering the cost of materials and my labor.
DSCN4826 by richardhayes454, on Flickr
DSCN4833 by richardhayes454, on Flickr
Jute padding is an effective holder of air pockets and blocks heat very effectively. Reflectix is a nice product, but doesn't have the insulating capabilities of uncompressed jute. But, over 40 years, the jute compresses and loses its insulating prowess, the rear hood seal flattens and allows heat into the air intake, and the kickpanel door seal goes 'South'.
Fix all that stuff and it's better inside.
Also.......I m sure my car is cooler with the side pipes , than it was with the stock under car exhaust . Putting the heat out to edges helps. I say significantly cooler.
BB will throw a lot of heat into the cabin .
Firewall, gaskets , grommets , insulation , all that needs to be there in good shape.
I haven't added any additional insulation . But I can see how it would help.
Seal up your firewall good.
"Here ya' go!" Click on the link below and have fun! (I read the "whole thing" and learned a lot)
https://www.corvetteforum.com/forums...=interior+heat
EDIT: OOOOPS....you already found it!
http://www.zip-corvette.com/catalog/...-weatherstrip/
Unfortunately, this book hasn't been published in several years and the price for a used copy can run several hundred dollars. Maybe some of the owners clubs out there has a copy that can be borrowed. I can tell you that if you do just half of what he recommends you will see big, as in 30 degree differences in interior heat.
Enough said.
Enough said.
