Upgrade HEI distributor
Old Feb 8, 2015 | 12:09 PM
jgonzo's Avatar
jgonzo
Default Upgrade HEI distributor
Hi all. I have an '82 crossfire. Thinking of upgrading the distributor, and then upgrading with new spark plug wires to dress engine up a bit. Any suggestions? Would also like to upgrade valve covers.
Old Feb 8, 2015 | 12:36 PM
GUSTO14's Avatar
GUSTO14
Wow, that's gonna take some doing! You already have one of the most reliable and highest performing distributors Chevrolet ever put on the first generation small blocks. Valve covers as well. The first generation SB (with the tin covers) was notorious for leaking oil down the sides of the engine. The C1-C2/LT-1/L-82 cast aluminum valve covers were the go to valve covers for every performance enthusiast that wanted a quick cure to that problem.
On the other hand changing out the plugs/wires/distributor cap/rotor for a new set of originals could well be an upgrade, especially if the originals are still installed.
Now if you're talking about adding "bling" that is another matter all together, just don't confuse that with an actual upgrade.
Good luck... GUSTO
Old Feb 9, 2015 | 08:35 PM
69427's Avatar
69427
From: I tend to be leery of any guy who doesn't own a chainsaw or a handgun.
What specifically is lacking in your distributor's performance that is requiring an "upgrade"?
Old Feb 10, 2015 | 05:05 AM
7T1vette's Avatar
7T1vette
I'm guessing "..it don't look like a Mallory..."
Old Feb 10, 2015 | 01:39 PM
hugie82's Avatar
hugie82
I'm pretty sure the 82 crossfire runs a different coil than the standard chevy. The wire color was used in Cadillac and I think oldsmobile. Something to check out if you order a High Output coil and cap.
I hope you are not thinking you'll feel any power gains? Our engines fall on there face, way before our ignition is being maxed out.
Old Feb 10, 2015 | 07:01 PM
96 lt-4's Avatar
96 lt-4
Modifying the advance curve for quicker advance may be beneficial so long as it does not affect anything with the crossfire setup.A good tuneup with high quality cap/rotor/wires is never a bad thing so long as it is needed.
Old Feb 11, 2015 | 03:58 PM
wilcar's Avatar
wilcar
When I did the carb conversion on my 84 xfire I used my original cap , rotor and coil with the accel non computer hei with no problems. Since your xfire hei is computer controlled adjusting advance curve will require a custom chip.
Old Feb 11, 2015 | 04:57 PM
chevygod's Avatar
chevygod
Is the HEI in an 82 equipped with any sort of modifiable advance, either vacuums or mechanical?
If the distributor advance is computer controlled, you probably won't realize much improvement without getting into the programming.
It is hard to improve on a correctly running HEI.
good luck,
Tom
Old Feb 14, 2015 | 01:33 AM
7T1vette's Avatar
7T1vette
I'm sure the programming in the factory Cross-Fire ECM is written for:
1) Lowest warranty! (meaning, modest performance)
2) Lowest emissions! (meaning, poorer performance and less mileage)
3) Lowest cost!
That's just the way GM works. If you want to improve performance, you'll have to modify the programming.
But, I had an '84 (in '83) and it ran fine, got decent mileage (much better than a non-ECM car) and performed 'adequately'. It could do 130 mph, so it was better aerodynamically than prior years.
Old Feb 14, 2015 | 03:58 PM
74 LS4-454's Avatar
74 LS4-454
Finalist 2020 C4 of the Year - Unmodified
Hey hugie, speak for yourself..... had the 82 out this AM before the snow, had to pull somewhat of a hole shot at this one light, and started losing the rear end, going sideways.....now that never happened before, so much for the CFI falling flat on its face.....
On a serious note to the OP, I put a MSD cap, and rotor, and upgraded the ignition module & coil with Pertronix units. Just get the coil with the correct color wires. Would have to look at mine again. My engine runs great and I am now over 130,000 miles on my "dd", starts right up everytime, no hesitation, and still surprises a lot of people for a 33 year old machine.
I don't feel there is a need to upgrade a HEI other than what I just mentioned. As others are saying, they are extremely reliable units.
Good luck.........Tom
Old Feb 15, 2015 | 02:35 PM
Wrecked82's Avatar
Wrecked82
DUI Distributor (which will have its upgraded module and high voltage coil), magnecor wires and iridium plugs.
Old Feb 15, 2015 | 03:06 PM
jb78L-82's Avatar
jb78L-82
The HEI distributor is a great, reliable unit for most cars but it can be upgraded in certain applications where higher voltage may be beneficial such as high RPM applications. The stock coil and module are well known to fall off in performance above 4,500 RPM (although probably not an issue with a stock CF engine). I replaced the coil and module on my L-82 over 20 years ago with aftermarket units with no issues (and no noticeable gain in performance in a stock engine, although it did improve idle smoothness). I am planning to replace the stock HEI unit this Spring since the weights have been sticking with a MSD E unit, primarily since it comes with a vast variety of advance curve choices and has a built in rev limiter which I can set to whatever RPM I wish along with a high performance coil and module for my rebuilt 355 L-82. The MSD E distributor is pricey though for most applications and probably overkill for a stock type engine.
Old Feb 15, 2015 | 03:18 PM
69427's Avatar
69427
A "high voltage" coil only means it has high dielectric/insulation capabilities. That is completely different from any electrical (ie: voltage, current, energy) output specs.
Old Feb 15, 2015 | 10:16 PM
cagotzmann's Avatar
cagotzmann
Skip the MSD E and go direct to the 6530 Programable. This does required a Locked out distributor and the addition of a GM 1 bar map sensor. The MSD e does allow you to change the curve simply but you will find you dont have as much control as you may like with a modified engine.
http://www.msdperformance.com/WorkAr...id=15032386286
vs
http://www.msdignition.com/WorkArea/...id=15032386168
The 6530 is a computer programable unit. you have 2 curves to set.
1 run retard curve
2 boost / vacuum curve ( map sensor )
Run restart curve 0 - 25 degree change
boost / vacuum curve 0 - 25 degree change.
I installed this in my 78 with a ZZ383 and love the idea that I can change the curve on the fly without using a single tool.
There are many features that I dont use since they are mainly for drag racing, but I use the run curve,vacuum curve, rev limit.
Also being a unit that retards timing vs providing advance you need to think differently. You also need to consider rotor phasing.
Old Feb 17, 2015 | 01:56 PM
Wrecked82's Avatar
Wrecked82
http://performancedistributors.com/p...ing-coil-kits/
"Our Racing DUI Coil Kit is designed for high revving engines that spin more than 7000 rpm’s. This coil is capable of 10,000 rpm’s, that is almost twice the output of a stock HEI coil! The Racing Coil comes installed in a brass terminal cap and includes the rotor and nylon rotor hold down screws. With the higher voltage output, spark plug gaps can be opened up to .055″. The wider plug gaps will allow more spark energy into the combustion chamber providing a better burn of the fuel mixture for increased horsepower. The Racing Coil Kits fit all GM V8, 6 cylinder and 4 cylinder HEI/DUI distributors."
Old Feb 25, 2015 | 09:15 PM
69427's Avatar
69427
"Our Racing DUI Coil Kit is designed for high revving engines that spin more than 7000 rpm’s. This coil is capable of 10,000 rpm’s, that is almost twice the output of a stock HEI coil! That's not output, that's dynamic range. Two different things. The Racing Coil comes installed in a brass terminal cap and includes the rotor and nylon rotor hold down screws. With the higher voltage output The coil does not determine the gap voltage. The gap voltage is mainly determined by the cylinder pressure and the gap width. , spark plug gaps can be opened up to .055″. The wider plug gaps will allow more spark energy into the combustion chamber A wider gap increases the spark voltage, not the spark energy (the coil determines the energy level). A wider gap also shortens the plug "burn" time. There's no free lunch here with wider gaps. providing a better burn of the fuel mixture for increased horsepower. The Racing Coil Kits fit all GM V8, 6 cylinder and 4 cylinder HEI/DUI distributors."
In all likelihood this is probably a very good quality product. My point here is that I don't see any technical information/specs regarding this product.
Old Feb 26, 2015 | 10:36 AM
gungatim's Avatar
gungatim
come on, it says "Racing Coil", isn't that good enough? and it must be good if it has to have a "Danger" sticker on it...
To Upgrade HEI distributor
Old Feb 26, 2015 | 10:55 AM
69427's Avatar
69427
Well, I certainly can't argue with that logic.
Old Feb 26, 2015 | 08:44 PM
Wrecked82's Avatar
Wrecked82
Then, ignore my post and you won't have to post childish responses anymore. If their product was not what is advertized, they would not have been selling them for years. There are other distributor manufacturers/distributors that advertize the same thing, absent the coil sticker. GO AFTER THEM!
Old Feb 26, 2015 | 08:45 PM
Wrecked82's Avatar
Wrecked82
http://www.jegs.com/p/Proform/Profor...46781/10002/-1
http://www.eastwood.com/distributor-...ance-unit.html
http://www.taylorvertex.com/hei-distributors/
Shall I go on?
