I need new radiator hoses for my 1979. I keep seeing early or late. what was the number of the s/n break? My engine code is 8 does the denote the break?
"the First design 1979 uses 1 1/2" ID hose; Second design uses 1 1/4" ID hose."
So it sounds like you need to measure and see what ID hose will work.
The hose you need, is determined by measuring the ID.
I suspect that the 1 1/2" ID is the more common 79 upper hose. There were a number of changes made at the very end of 79 production. Changes intended for the 1980 Corvette, such as the 85 MPH and 2 door rear storage compartment, were pulled forward into the end of 79 production. This was done around June or July of 79, for the last month or so of production. It's very possible that the change to the smaller inlet radiator, was done around the same time as the other changes?
