1980 vette weight
Old Feb 9, 2015 | 08:31 PM
Romasko's Avatar
Romasko
Cruising
Default 1980 vette weight
I have a 1980 that I weighed about 7 yeaes ago and it came in at 3250 with a full tank of gas and me in it. I got rid of the air pump, the AC, cast iron heads, I went with aluminized duel exhaust, a be cool radiator and duel fans. I took out the rear tire and Carrier I just bought the big daddy kit from VBP and will be putting it in this spring will have to see where I end up. On the down side the aluminium center section is gone and has been replaced with a cast iron unit and I now have chromoly drive shaft and half shafts, offset trailing arms and there not light either about 15 pounds more. I hope I come out at about 3100 will have to see.
