A Specific Rear Carpet Installation Question
Btw, any other carpet installation tips (quality/appearance and time saving) you have personally found are very welcome to hear about for me and others. I believe I will lay down both, hush mat and reflectix on top of the hush mat when I soon install it, hoping there aren't many trade-offs with such a dual insulation for noise and heat abatement purposes. Thanks for help in the past.
I'm surprised no experts on the forum are giving up their secrets to making it tight around the wheel wells as I've seen. Perhaps a lot of 3M tacky glue.
I have info on the rear humps and how to install them.... on stock correct carpet.
Willcox
Willcox
respectfully,
David V.
I'm in the middle of solving the color and fit issues on the 1968-1977 cars, I've not even started with the 1978-1982 cars but I do have tons of original samples when I do. (and that should be fairly soon).
Willcox
Willcox
Regardless, I'm now interested in figuring out how to perfectly install around the wheel wells.
I have boxes of original carpet samples we managed to store for years. It's almost a must... it keeps the carpet people in line!
I'd like to take you up on a sample of that carpet, I'd like to see and how it compares to my sample here. If you don't mind email me your address to support@willcoxcorvette.com and I'll have my shipping department send you a mailing label.
The original sample I have here I think is the perfect sample for your color because it is a NOS lh 14048313 rear storage compartment door which has the carpet on it. I wonder what color code was sent to you, the ACC code should be 8046 for your silver green carpet. (also batches change too, dye lots are always a few tiny shades either way so it's possible the lot changed since my sample was made).
Here is 4086 sitting on top of the original door. At first glace it looks good but there is a tiny bit of a difference.
In regards to having the essex as an option... Sure it's possible for us and I'm sure we don't sell that many based on the fact that we don't promote it or have it on the site. One reason is that you are limited to just 12 colors and another reason would be the cost. Our cost alone increases over 150.00 for the set.
Below is a picture of the essex carpet next to a GM next to ACC next to GM again. Obviously the essex is taller than the GM and I love the way it feels. Looking at the first picture below and looking for a difference between the original and the ACC carpet... I really don't see much difference in this picture...
So after taking that picture I had the idea to lay both carpets face down and yes there is a difference which was about the thickness of the plastic backing.
I own a low mileage original 78 and this car like yours, has had the EGR valve, plugs, and plug wires changed and that's it. The carpet in this car is the same thickness as the samples I posted, pictured below. This picture is from our facebook page in the factory flaws album. This is exactly the way the car was delivered new.
What makes this bad is all the major carpet manufacturers purchase their carpet from the exact same mill... Dorsett Industries in Dalton Georgia and the acc cutpile carpet set pile weight is 14 oz sq yd. and the 80/20 loop is 20 oz per sq yd.
How to fix the wheel wells..... Heat...
Heat the back side and it will soften when it cools it will stay where you put it.
Willcox
