Weatherstripping
Old Feb 14, 2015 | 07:43 PM
Calo69's Avatar
Calo69
St. Jude Donor '15-'16, '18
Default Weatherstripping
Looking to install new side window vertical weatherstrips, have correct pair( I believe) for late 69 coupe. Looking for any tips, help etc. on swap.
Any screws? Clips? Glue etc. thank you
Old Feb 15, 2015 | 09:32 AM
Easy Mike's Avatar
Easy Mike
Cruise-In II Veteran
Originally Posted by Calo69
...Looking for any tips...
The AIM helps a little. 3M automotive weatherstrip cement for adhesive. What is the air temperature where you're working? The 3M likes warm temps.
Old Feb 15, 2015 | 09:42 AM
Alan 71's Avatar
Alan 71
Hi C,
It's a good idea to dry-fit the piece first so you can see how the vertical lip on the weatherstrip fits into the weatherstrip retainer flange.
Also mark the vertical position so you don't have to slide the weatherstrip up or down once you've applied the glue and put the strip in place.
Good Luck!
Regards,
Alan
Old Feb 15, 2015 | 10:16 AM
Calo69's Avatar
Calo69
Thanks, temp in garage now 50 - 60 deg. I'll check out the adhesive.
Checked AIM page j312 diagram ok but no mention of any type hardware
( clip, screw ) etc.
thanks
Old Feb 15, 2015 | 10:23 AM
Calo69's Avatar
Calo69
Originally Posted by Alan 71
Hi C,
Good Luck!
Regards,
Alan
Thank you, from your answer am I to understand it is only attached In Flange with adhesive? Reason I am asking is replacement pieces have a small hole at corner, didn't knowif there was a screw or pin needed to retain with adhesive.
On a side note I have seen many of your replies to questions and quite frankly I'm amazed at the pictures you provide for reference.nice job
Greg
Old Feb 15, 2015 | 10:36 AM
Alan 71's Avatar
Alan 71
Hi Greg,
I didn't mention the lower hole because I wasn't sure if 69s used it.
I don't see it in the drawing Mike posted.
My 71 has a pop rivet at it's bottom. (Set from the inside.)
Regards,
Alan
Old Feb 15, 2015 | 11:02 AM
Calo69's Avatar
Calo69
Thanks, from what I can see it looks like I'll have to pull panel to access. Please correct me if I'm wrong, thanks again.
Greg
Old Feb 15, 2015 | 11:42 AM
Calo69's Avatar
Calo69
Thanks Mike didn't see your attached image, much clearer than one I was looking at.
Greg
To Weatherstripping
