Jack Placement
Old Aug 9, 2002 | 08:45 AM
Blackened 79's Avatar
Blackened 79
Default Jack Placement
Where is the best spot to position a jack (front and rear) to raise the
nose or tail ? :confused:
Old Aug 9, 2002 | 11:37 AM
drspeedy's Avatar
drspeedy
Default Re: Jack Placement (Troublemaker 71)
On the front of the car, place the jack almost directly under the air vent, about half the distance between the front tire and the door. For the back, go about 6-8 inches from the rear tire (towards the front). Just make sure that you've got nothing but frame when you start to put weight on the jack- fiberglass doesn't hold up real well under stress:eek: ...
-doc
Old Aug 9, 2002 | 11:47 AM
Blackened 79
Default Re: Jack Placement (drspeedy)
I meant to raise the entire front (both wheels) or back...not only one side.
Old Aug 9, 2002 | 06:44 PM
drspeedy's Avatar
drspeedy
Sorry 'bout that.
However, I think that doing it one side at a time might be the most eficient and safest:smash: way to get it done. Check out this thread and see if it helps any:
http://forums.corvetteforum.com/zerothread?id=358018
I can't be of much help for getting the whole front or rear at once... never done it.
-doc :troll
Old Aug 9, 2002 | 06:59 PM
Bohot's Avatar
Bohot
See this link...
http://users.erols.com/jerryp58/corvette/jackpts.jpg
To Jack Placement
