Speedometer Gears in Thransmission
Your friendly Chevy dealer sells speedo drive gears that are easily inserted in the tail end of the tranny. They seem to come in 1 tooth increments. They are only a couple bucks each. I believe you need to add a tooth when you use smaller tires. A 69 Camaro with 3.73 gears had a smaller diameter tire than the Vette and still used the same tranny. This might be a possible combination.
Yet to put it simply, if you have a 5% change in your tire diameter, you need a 5% difference in the number of your speedo gear teeth to keep everything accurate. I used my GPS to callibrate my speedo to actual. If you have access to one, do this before you buy a gear since you may have been already out of wack and didn't know it. Whatever your current speedo error is as a percentage of actual is the same percentage of teeth you need to change on the gear.
Chuck
[Modified by Chuck Harmon, 10:49 AM 8/9/2002]
