Dual carb set up.
Old Feb 24, 2015 | 07:40 PM
Black_Magic's Avatar
Black_Magic
2020 Corvette of the Year (appearance mods)
C2 of Year Winner (appearance mods) 2019
CI 4-5-7-9-10-11 Car Show Winner
CI 2-3-4-5-6-7-9-10-11 Vet
It's going to be a trade off, no way will a 2 4 intake work great ran progressive, it wasnt designed to, ask the builders of these intakes what they think of the idea....
Mine is Elelbrock intake, carbs & linkage. They designed and sell as a unit. Over 7,000 mile including 4-5 trips to Bowling Green for cruise-in's without 1 problem starting or driving with Cruise-control or A/C on.
I know 4-5 local guys (non-Vette but SBC) that are running same setup with out problems.
Check it out ===> Click Here
George
Old Feb 24, 2015 | 07:50 PM
John 65's Avatar
John 65
George
That is a work of art, as is the rest of your engine. Very nice!
Old Feb 24, 2015 | 08:05 PM
Calo69's Avatar
Calo69
St. Jude Donor '15-'16, '18
George
Have similar set up, only tall intake and satin. Did you keep jets, rods etc. as they came?
Old Feb 24, 2015 | 10:48 PM
The13Bats's Avatar
The13Bats
Check it out ===> [/url]
George
It didnt say it was meant to be ran progressive, unless the intake is designed for that then it works but not as good as one single carb, you have my interest I will call edlebrock tomorrow and see what they say about progressive set up...
Old Feb 25, 2015 | 08:40 AM
Black_Magic
Only thing I change was the fuel line(s)
Car has never stumbles and when I checked the plugs @ about 5000 mile they all look good and same color. Also original "POINTS" distributor tuned by "LARS". Still running points & plugs I install when I installed the engine.
Again as I stated above these were added for looks -- way to much for stock heads/cams/etc but perfect for looks.
If you are looking for "GO FAST" then look at single 4 bbl Barry Grant Demon Carb 750cfm on top of a BBC like in my '31 Ford
BTW...They also look GOOOOOD
George
Old Feb 25, 2015 | 10:14 AM
Calo69's Avatar
Calo69
George
Very nice, thanks
Old Feb 25, 2015 | 10:39 AM
commander_47's Avatar
commander_47
Originally Posted by c3cruzn
This is why I love this site other than the nah sayers and they have there own problems. I love tinkering with my cars I built them so why not tinker. I have never done a dual quad set up so this is why I asked a simple question. Sticking with the dual's cause it will look better for a 1980, I am planning on going to 3 2's in the 59 because that will look better in that car. Thanks for all the great advise and when I go to Jefferson in April I will be looking for some new toys for the rides. Thanks again and God Bless all.
Dual quads are definitely the Bomb.
They look way cool, aggressive and dominating.
Back in the day they were good for some performance gains, but over time it was discovered that a single 4 barrel can perform better.
IMHO that doesn't diminish their cool factor or performance factor on our old school cars one tiny little bit.
I have not used a dual quad setup in quite some time, but I'm seriously considering it for my 454.
I've heard nothing but good reports on the Edelbrock setup. My only concern would be the 500 cfm carbs. Like Lars mentioned, you run the risk of running a little lean if not set up right.
You could try the Holley setup which uses dual 450 cfm carbs. I believe this may be more of a performance setup if you have the hood clearance.
http://www.summitracing.com/parts/cmb-03-0181
Old Feb 25, 2015 | 07:16 PM
The13Bats's Avatar
The13Bats
I am a bit surprised to hear you say giving up some performance for looks is worth it to you as no nonsense as you were in that qjet on a performer thread, next you will say you are gonna run dual qjets on the dual intake, is the intake you posted open / shared plenum where it can be ran progressive? I cant tell for sure in the pictures. looks tunnel ram-ish.
Back to the other intake, I called Edelbrock about
http://www.jegs.com/i/Edelbrock/350/54254K/10002/-1
According to the tech they recommend this to be ran progressive it has a plenum designed for that, and while he said that one carb would perform better he also said the dual was good for a couple extra hp, so I had to wonder which is really better,
He then went on to say the big draw for the dual 4 is basically looks not performance and does take some setting up the carbs to really work correctly.
My confusion before was with tunnel ram type 2 4 intakes that can not be ran progressive.
Old Feb 25, 2015 | 07:26 PM
commander_47
um......DUAL q's?????????? not likely
But that Holley setup shown is the lowest tunnel ram setup. Another kit has a tall setup.
They might could be put on another manifold set up to run progressive. Those carbs are fairly inexpensive and a little lower cfm.
I only mentioned those because of the lower cfm.
I do have a buddy with the Edelbrock system on his 78 c3 and they work wonderfully. progressive, easy to set up and look great with the shiny finish.
Heck, if one Holley is great, Two MUST be superlative!!!!
Old Feb 25, 2015 | 08:31 PM
doctorgene's Avatar
doctorgene
The Dual four set-up is just beautiful. I had the factory set-up on my 56 Corvette, back in 62, I didn't have many people out run me either, only the fuel-injection cars. There was a 39 chevy that had a Arm with a string wrapped around it, & a hypo needle stuck into the arm,, with a note under the drawing, Fuel Injected!! Another 55 chevy with dual fours, called (The Rattler) was no one to bet on either. Give me those days back. No B. S. from the EPA either! Let me see some more dual or 3/2 set-ups on these cars. Have a great one. Gene
Old Feb 25, 2015 | 10:19 PM
Little Mouse's Avatar
Little Mouse
from 3500 on up a street tunnel ram will put more power out then any dual plane manifold or single plane. But that's not doable for most on a vette.
This is the new two fours of the modern day period lol.
Old Feb 25, 2015 | 10:21 PM
Little Mouse
Nice looking manifold for a ford.
