Dual carb set up.
Here's my question, If I add a slip linkage will the 2nd carb sit there and not dump a lot of fuel under normal driving conditions?
number 2, When you kick in the 2nd carb, will there be to much gas dumped into a stock engine causing a lack of performance instead of an increase in power.
I had a thread yesterday about adding some performance to my L48 with dual carb setup. After reading advise from other members, i realized that unless I'm putting in a new crate motor I'm just wasting a lot of money and time. considering what it is the performance is pretty good and with the exhaust system sounds even better. I'm hoping the dual carb setup will make it look very cool without a bunch of problems. I'm going to the Jefferson swap meet in April so depending on what I read could be adding a new show piece before the next show. Thanks all
Gary
Are you going to use two 400cfm carbs or smaller? Because at 800cfm you'll already be over carbureted.
It's not the extra fuel that will cause a problem so much - because you can jet and re-calibrate the carbs properly , but the extra air could cause a bog if not setup properly.
You will be running on both primaries at the same time with two 4's , not a big deal or a deal breaker either.
Setup is crucial , you want balanced vacuum secondary carbs for sure. A pr of Holley 390's may be it !
But with the progressive linkage (See Below) you can just drive on the back carb and when you mash-it the front card will DUMP lot of extra fuel.
But I still like the looks. More pics ==> Click Here
George
All that said....a slightly better cam would help...and certainly any other heads...but for what it sounds like you're doing..go for it...they will drive fine with the right linkage setup.
I would spend some time on the timing curve. Try to add some initial timing and then limit the total advance. It will help driveabilty with any carb on a milder engine.
JIM
just like all the other CHROME GOODIES I LIKE
George
ZZ4 Crate -- TKO 5 Speed prior to installing in my '65
http://trademe.tmcdn.co.nz/photoserv.../358405630.jpg
On the systems I've built, I've set them up so that the front carb was the primary carb. Both front and rear carbs have active and functional idle systems, and it's important that the idle speeds and idle mixtures on both carbs be set up exactly the same so you have the same idle air & fuel flow through both ends of the engine. I've then used an adjustable progressive linkage from the front carb to the rear carb, which delays the opening of the rear carb until the front carb is at about 75% of its throttle opening: Smaller engines need the rear carb to be delayed more - bigger engines can take the rear carb opening sooner.
Opening of the rear carb, when engine demand does not need the airflow, does not result in fuel "pouring into" the engine. It results in a massive lean condition, with air, and no fuel, entering the engine. This will cause the car to fall on its face. This "fall on face" problem is due to excessive airflow capacity for the engine's needs, with inadequate fuel enrichment as the throttles open. It's a tuning issue you'll have to work on to get the timing of the throttle opening rate just right. If you have more time than money on your hands, it will keep you entertained for quite a while.
Lars
I have a 69 bb, I want a tri power badly, but they cost more than a good fuel injection system so it just wouldn't work in my head to pay more for something that will never perform as well as even one carb but is just "looks" cool.
I liked that idea of driving on the middle carb then when I needed it the outer two kick in, but I like more the idea of one simple carb, tuned to get down and boogie when I desire.
I do not believe that when designed the dual 4 intakes with one carb in front of the other were meant to be ran progressive, it's certainly not an optimal way of using that design intake,
A lot more eye candy would be a cross ram with side by side 4's but you cant run them progressive at all, they have to come on together and it's a high rpm intake it will kill any low torque you had.
But I wonder if you could just put a thin block off under the front carb and just run off the rear carb, at least you would have three times the cfm you need.
I am old school custom my self, Almost bought a 4 weber set up that I needed like a hole in the head, but again the single 4 barrel wins out, it will have some old school cool air cleaner. In the world of old school hot rod parts they have adapters that bolt to a 4 barrel intake, they make them for dual carbs and tri powers, many cats set them up to work progressive, take a look at vintagespeed.com Inglese has a cool old school set up it mounts two side draft webers out each side and can be ran progressive, but the intake must be open plenum to work correctly when you romp on it.
still it's going to be a looks thing, one carb would do better.
I do support whatever you desire even if it is for looks, just try to do it in a way that you will be happy with....
Here was the 81 wide body I built in 89...see I dig eye candy mods...
Lars
